Author Topic: 1967 Dash fitment. Commonly poor?  (Read 1238 times)
1967 eight barrel
  • Guest
« on: April 25, 2016, 02:17:29 AM »
I am starting re-assembly on my Shelby's dash. The cluster doesn't seem to want to seat completely flush to the dash on the left side. Is this a common issue that requires fitting for the heater control panel? It has a very small gap, and I can't seem to see anything that would keep it from seating.
        -Keith
Re: 1967 Dash fitment. Commonly poor?
« Reply #1 on: April 25, 2016, 03:58:39 AM »
Repo, NOS, original, or original rechromed?
1967 eight barrel
  • Guest
« Reply #2 on: April 25, 2016, 04:57:24 AM »
Original, re-chromed. I also went and borrowed a reproduction. Same issue. The cluster is straight. I thought about the process causing an issue. It was done by Vacuum Ornamental in Michigan,
                                                        -Keith
« Reply #3 on: April 25, 2016, 05:48:56 AM »
I seem to recall a few cars having a shim stock behind the heater control mounting at the upper end.
Maybe post a picture of the fitment issue? Dash pad shrinkage (original pads) can cause some issues too, very common.
1967 eight barrel
  • Guest
« Reply #4 on: May 06, 2016, 01:14:38 AM »
The left hand side where the lower screw goes, as well as the left speedometer ring doesn't fit as well as I'd like.
