Author Topic: 70 Boss 302 - Third member retaining nuts colors  (Read 1677 times)
Offline bkross
« on: April 21, 2016, 01:33:14 AM »
Does anyone know for certain the correct finish of the attaching nuts for the third member for a 9 inch rear in a 1970 Boss 302?
Thanks, Bill
« Last Edit: April 28, 2020, 08:54:43 PM by J_Speegle »
1967 eight barrel
  • Guest
Re: third member colors
« Reply #1 on: April 21, 2016, 04:11:15 AM »
Ford specifies S60 as the finish. S60 is Phosphate and Red. If you have the carrier out, you might consider ordering the AMK nut and washer set for the carrier. They come with enough hex lock nuts and copper washers to replace them all.
The kit number is: F785.  It's 12.00
        -Keith
« Reply #2 on: April 21, 2016, 07:43:53 PM »
+1 They will be looking for red dye nuts (believe you'll find them lighter than the dark phosphate under the red) and as mentioned do not forget the thin small washers or you'll have leaks ;)
« Reply #3 on: April 22, 2016, 01:19:22 AM »
To add. I believe the 68-70 nuts were zinc dichromate dipped in the red dye . The thin small washers are copper in material.
