Author Topic: hole in floor pan under accelerator pedal 1966 Coupe  (Read 1097 times)
Offline Robert LeBlanc
« on: April 18, 2016, 06:37:42 PM »
I removed old carpet and I have a  small hole directly under the accelerator pedal?
Seems to have an indention around the hole like something was supposed to fit there.
Any idea what this is for?
1967 eight barrel
  • Guest
Re: hole in floor pan under accelerator pedal 1966 Coupe
« Reply #1 on: April 18, 2016, 08:40:25 PM »
The hole you're referring to is about two inches from where the Emergency brake cable passes though right where the floorboard meets the firewall, correct? It should almost be directly behind the top of the brake pedal. If that's what you're talking about, it is for the speedometer cable for an Automatic or Three Speed manual transmission.
        -Keith
Offline ChrisV289
« Reply #2 on: April 18, 2016, 08:54:52 PM »
I think he means right under the pedal on the floor board where your heel would be. I saw another car like this but thought it was a PO did something
2009 V6 Mustang Coupe
« Reply #3 on: April 18, 2016, 11:20:48 PM »
Think the question requires a picture.  ::)
« Reply #4 on: April 18, 2016, 11:58:38 PM »
yes, hole is pretty much under the spot where the  heel would be located  on floor pan
 I will get photo later as vehicle is off location,
thanks
