Author Topic: 67 GT Fog Light Grille Bar ~California Pony Cars Repoductions  (Read 2576 times)
Since the RH one of my original bars has a small crack & slightly bent AND all parts would also need re-chromed to be perfect ( I could MuggyWeld the crack)...I thought I might try other ideas. NOS is getting tough to locate. I found a NOS horse & corral that only needs a little re-paint work so that should work there instead of re-chroming the original.
Has anyone bought these California Pony Cars reproduction Fog Light Bars? Are they close enough for a Concours Driven Class?
Here is one vendors description:
California Pony Cars Fog Light Bar Chrome Pair 1967:
Pair of California Pony Cars Chrome Fog Light Bars for all 1967 Mustangs.
Are you looking to replace or upgrade the fog light bars of your 1967 Mustang? Then take a good look at this new Pair of Chrome Fog Light Bars manufactured by California Pony Cars. Created to be direct replacement pieces of equipment for your OEM fog light bars, these fog light bars are crafted from superior die cast metal with a brilliant chrome plating.
California Pony Cars Fog light bars are made with precision, die cast tooling. This guarantees that your fog light bars have perfectly clean lines and accurate dimensions, ensuring a perfect fit for each fog light bar. Each fog light bar has been engineered and made of the finest materials in the United States from California Pony Cars.
California Pony Cars Chrome Fog Light Bar Pair Includes:
- Concours Correct Right Hand Fog Light Bar and Fog Light Housing
- Concours Correct Left Hand Fog Light Bar and Fog Light Housing
- All Installation Mounting Hardware
The finishing process for each of these fog light bars involves an acid-cooper chrome plating that reinforces the fog light bars to be able to withstand all the harsh conditions that the elements will be able to dish out on them. This protective layer will also help to keep these fog light bars shining with the great lustrous finish for the life of the part. All the necessary installation hardware also comes included.
Please Note: This pair of Chrome Fog Light Bars is completely Concours correct. They will install and fit seamlessly onto your show quality 1967 Mustang, while at the same time not causing any problems when it comes to judging.
« Last Edit: April 18, 2016, 03:36:49 PM by 67gtasanjose »
1967 eight barrel
  • Guest
Re: 67 GT Fog Light Grille Bar ~California Pony Cars Repoductions
« Reply #1 on: April 18, 2016, 08:25:06 PM »
What's "Cooper" plating? It reinforces the bar and protects them from the elements?  ;D I can't speak for the fog lamps bars, but stay away from their fiberglass.
        -Keith
« Reply #2 on: April 21, 2016, 06:54:59 AM »
I went ahead and purchased a pair of these and the castings are built very much identical to originals except the factory casting marks such as "Prestolite" and engineering numbers.
I do not believe they are painted correctly, they seem to have left too much of the chrome visible. (area behind the fog light still chromed front and back, including the mounting area. The underside of these are also chromed and I suspect they would have been painted from Ford. Summarized, the reproduction are only painted on the top sides of the bars, the rest is all chromed)
I could use somebody inspecting their "known originals" to see what areas are chromed, where the paint is and where the paint is not.
Since I know that I had repainted my originals years ago, I am no longer positive how they may have been originally. Because of this, I just took a look through several pictures of other low mileage unrestored examples at this site. Not much help on this detail but it appears that the only portion of the fog light bar that is NOT painted is the narrow leading edge of the bars. This is how my originals that I repainted 20 years ago look today too.
« Last Edit: April 22, 2016, 06:01:39 AM by 67gtasanjose »
1967 eight barrel
  • Guest
« Reply #3 on: April 22, 2016, 05:22:23 AM »
Those look very well made. The plating is nicely done too.
        -Keith
« Reply #4 on: April 22, 2016, 06:10:10 AM »
        -Keith
Yes, the chrome is very mirror-like :) In image #2 of previous post, you can almost make out the mirror-image of my 67 Mustang logo within the patch on my  work shirt (seen in the reflection of me taking the picture)...Picture of my work shirt logo attached. I've had these on my uniforms as a company logo for over 12 years...I've used the logo on my checks and at times on company letterheads.
Getting back on track,
I still could use somebody looking closely at original Fog Light Bars to describe known original paint masking process to these, particularly: What should be seen as CHROMED after painting
« Last Edit: April 22, 2016, 06:33:21 AM by 67gtasanjose »
« Reply #5 on: April 22, 2016, 10:58:15 PM »
Richard here is a original that I have for a project that I have not restored yet.
It is pretty much painted every where except for the ledges and the center of the cup. Hope this is what you needed.
« Reply #6 on: April 23, 2016, 09:58:52 AM »
Yes, this is how my originals were painted now (but I do remember that I had repainted them before, why I asked)...I suppose I'll need to repaint the reproductions the same way. Thanks
One last question that hasn't been answered regarding "Judging"...
If these were repainted correctly and since otherwise no notable differences except not being factory assemblyline parts, these would be acceptable in "Concours Driven", correct?
« Last Edit: April 23, 2016, 10:02:43 AM by 67gtasanjose »
« Reply #7 on: April 23, 2016, 10:26:51 PM »
Richard,
Here are a few pics from an extra set I have.  Similar to Marty's but the center of the cup looks like it has more paint.
« Reply #8 on: April 23, 2016, 11:20:45 PM »
Reproduction parts are approve for both Concourse Driven and trailered class provided they look as and preform as the assembly line part. IMHO these would be fine if repainted.
« Last Edit: April 25, 2016, 05:48:24 AM by J_Speegle »
« Reply #9 on: April 24, 2016, 02:25:08 PM »
;)  8)
