Author Topic: '67 AC/Tilt vacuum canister  (Read 1448 times)
Offline Oz390
« on: April 17, 2016, 01:54:32 AM »
Believe the 67s used a kinda "bread loaf" shaped canister, as opposed to the later "coffee can" style.  I have one of the "bread loaf" shape and it has two 90 degree fittings, one about 3/16" diameter and one about 1/16" diameter. Neither has a check valve, as on my later "coffee can" ones.
Unsure if it should have a check valve on one connection, or if this style can was just an open path.   ???
8R03S : 76A I 2A 15M 72 5 U
Re: '67 AC/Tilt vacuum canister
« Reply #1 on: April 17, 2016, 02:49:21 AM »
67 has an external check valve mounted in line on the vacuum line.  As far as the can goes I suggest that you do some searching.  This has been a very hot topic more than once.   If I wasn't working from my phone I would add links to those posts for you.
Found a computer - here are some links:
http://www.concoursmustang.com/forum/index.php?topic=9931.0
http://www.concoursmustang.com/forum/index.php?topic=9499.msg56976#msg56976
http://www.concoursmustang.com/forum/index.php?topic=10629.msg63435#msg63435
http://www.concoursmustang.com/forum/index.php?topic=5644.msg58022#msg58022
http://www.concoursmustang.com/forum/index.php?topic=948.msg5024#msg5024
http://www.concoursmustang.com/forum/index.php?topic=9888.msg58820#msg58820
« Last Edit: April 17, 2016, 03:59:38 AM by 67gta289 »
Offline Oz390
« Reply #2 on: April 17, 2016, 09:14:39 AM »
Thanks very much.... :)
« Reply #3 on: April 17, 2016, 05:45:27 PM »
Yes you have some reading to do. Enjoy - but like most things 67 - lots of running changes and details.  Not an easy year to deal with
Offline Oz390
« Reply #4 on: April 17, 2016, 07:45:59 PM »
Thanks, but just confirming the part on the shelf's application so I can advertise it correctly.  Spare sale part, not installing as I have 68s.
« Reply #5 on: April 17, 2016, 10:25:13 PM »
Add some pics to this post.
