As noted, clamp, go slow, take your time. Localised pressure can help, for similar items I've use small blocks at the apex of the curve on the side you are pushing "in". Not just two flat blocks across the whole surface. This can apply a bit more selective pressure where you need it.
Some light heat may help, but may blemish/discolor chrome if you are not going to refinish...
