Author Topic: Replacing the Kick Panels  (Read 2304 times)
Offline Herman
« on: June 12, 2010, 06:47:19 AM »
I am in the middle of replacing my kick panels and was wonder what is the best way to fit the carpet?
Washing, polishing and cleaning stuff some more in an attempt to retain that 'Golden nugget'
Re: Replacing the Kick Panels
« Reply #1 on: June 12, 2010, 09:15:52 AM »
65-66?
Offline Herman
« Reply #2 on: June 12, 2010, 09:01:35 PM »
66 gt coupe with deluxe interior.
sorry should have mentioned that.  :-[
« Reply #3 on: June 12, 2010, 09:44:52 PM »
Hopefully you have your old kick panel to use as a guide.  If not, you need to fit the stainless strip and drill the holes before sticking the carpet on.  Once you do that, the carpet is glued to the kick panel.  The edge of the top should be just below the holes for the stainless strip.  Or, sometimes, I have seen the spears stuck through the carpet/vinyl edge.
Offline Herman
« Reply #4 on: June 13, 2010, 07:26:33 PM »
Thanks Charles,
However what happens to the black vinyl around the outer edge, Do you fold them around the edge of kick panel and glue to the back.
Herman
« Last Edit: June 13, 2010, 07:30:19 PM by Herman »
« Reply #5 on: June 14, 2010, 09:25:16 AM »
Yes, vinyl is wrapped and tucked.  You need a good contact adhesive to get this right.  Wouldn't hurt to scuff the plastic to get a better bite with the glue.  Make sure the surfaces are clean.
Offline rodster
« Reply #6 on: June 24, 2010, 11:55:44 PM »
Here's an example of what you mentioned, the spears are stuck through the carpet.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
