Author Topic: Backing Plate dab?  (Read 1546 times)
Offline ChrisV289
Backing Plate dab?
« on: April 03, 2016, 04:48:56 PM »
Was cleaning up my backing plate to soak and removed the parking brake cable and came across this blue mark. Anyone else see this before?
2009 V6 Mustang Coupe
Re: Backing Plate dab?
« Reply #1 on: April 03, 2016, 09:13:32 PM »
It may have transferred from the e brake cable if on a 65.
« Reply #2 on: April 04, 2016, 12:24:18 AM »
+1
Offline ChrisV289
« Reply #3 on: April 04, 2016, 11:46:30 PM »
Thanks Bob and Charles.  Looking back at your blog Charles, I see where the blue was, was actually on the rubber itself with yellow on the prongs.
« Reply #4 on: April 05, 2016, 01:43:48 AM »
Right, blue on the conduit ends for a V8 car.  The I6 rear cables were identified by yellow on the conduit ends.  Although both versions had the yellow lock prongs that are seen from the inside of the backing plate.
« Reply #5 on: April 05, 2016, 05:27:23 PM »
+2 Seen other colors - that woulds match the cables I removed
Offline ChrisV289
« Reply #6 on: April 14, 2016, 04:41:51 PM »
Opinion needed. Will this backing plate still work or will I have problems with these gashes?
« Reply #7 on: April 14, 2016, 04:51:02 PM »
if they were mine i would weld them up & grind smooth. grooves that severe will prevent the shoes from moving properly. now's the time to fixit. imo.
« Reply #8 on: April 14, 2016, 05:31:45 PM »
+1 . Good advice.
