Author Topic: 68 390 Motor Details  (Read 1446 times)
Offline gtamustang
  • CPM
« on: April 02, 2016, 10:50:36 PM »
All,
I am working on an early 1968 San Jose 390 GT fastback and I am looking for a little guidance (opinions and pictures) for a few items. The GT is an LA DSO, automatic, with power steering and A/C.
1. I am not sure what the alternator and smog mounting bracket(s) look like. Pictures would be very helpful
2. Based on my January 1968 MPC, the distributor may be a C8OF-12127-D or possibly a C7OF-12127-F. I think the vacuum control is a dual advance unit (top ports and no front port), possibly a C8AZ-12370-C, -E, or -A. Opinions and pictures for this.
3. I have read through previous posts on the correct A/C idler pulley and mounting bracket for the 390 (thank to Bob G for really good pictures in that thread). My question is how what this installed and used with the power steering pump bracket.
4. Last question is belts! I know the alternator gets two belts (2 of the 3 grooves on the crank and water pump pulleys), the power steering pump get one belts (1 groove on the crank pulley), and the smog pump gets one belt (1 groove on the water pump pulley). So what belt drives the A/C compressor? Is is a combo smog pump-A/C belt?
Regards,
Pete Morgan
Re: 68 390 Motor Details
« Reply #1 on: April 02, 2016, 11:10:50 PM »
Pete,
In the Library section of this forum, you will find a post titled "Mustang Distributors". You might find what you are looking for in there.
Offline DTruitt
« Reply #2 on: April 03, 2016, 03:12:16 PM »
Many of the the 390 GT engine pulleys, brackets, belts and belt routing are the same as the 428 CJ. You can get pictures of components here
https://www.428cobrajet.org/id-main
Also Mansfield Mustang specializes in Mustang Big Block parts, they have an excellent on-line catalog with pictures, as well.
Danny
1968 Raven Black, S- Code, 4 spd., GT Fastback, San Jose, March 1968
1968 Candy Apple Red, J- Code, C-4, GT Convertable, San Jose, April 1968 (SOLD)
1968 Raven Black, R- Code, 4 spd., GT Coupe, Dearborn, April 1968
MCA Gold Card Judge
