Hi,
How difficult would it be to rebuild from a washer plastic tank (blow moulded) to an original washer bag?
What is needed to do so?
- material
- manual work
- position
Found this on another source:
"On my '67 the washer bag bracket is mounted 1 3/4" below the top of the apron on the front end. It is mounted parallel to the raised part it is mounted on, making the rear end of it 1 7/8" below the top of the apron. This is measuring straight down, not following the contour of the apron. The front end of the bracket is 9 3/8" back from the radiator support. The bracket is spot welded on. This is an original apron and bracket".
Mine has a plastic tank, where it should be a bag
11/30/66
Would it make sense to replace?
