Author Topic: 67 rear axle brake line C7ZA-2A448-B  (Read 1773 times)
« on: March 28, 2016, 08:36:07 PM »
Removed an original rear brake line from a 67 the other day.  Thought someone might enjoy the pictures.  Something we would expect to see on a T-bred I suppose.  C7ZA-2A448-B
Offline preaction
Re: 67 rear axle brake line C7ZA-2A448-B
« Reply #1 on: March 28, 2016, 11:02:55 PM »
It looks a little past its service life ;)
« Reply #2 on: March 28, 2016, 11:43:54 PM »
We would expect to see a fresh one on a T-bred. I had heard David Davis was reproing single crimp 67 rear brake hoses.
« Reply #3 on: July 21, 2019, 08:44:48 PM »
I dug mine out as the rear axle restoration is looming.
Mine is still in one piece and the hose is still good.
The hose has broken stripes (not continuous) in maybe white, yellow or?
The reverse of the hose has numbers I can't make out.
The finish is dichromate on the bracket and then moves to a brass junction.
The hose crimp on that end appears to brass as well. Or is it worn off cad or dichromate?
I believe the hose crimp connection at the body is supposed to be cad or dischromate too.
Keep and refurbish or find another?
« Last Edit: July 21, 2019, 08:55:23 PM by Bossbill »
« Reply #4 on: July 21, 2019, 10:53:02 PM »
Keep and refurbish is my opinion. It still looks nice.  FYI all bass at junction. Zinc dichromate on other end.
« Reply #5 on: July 22, 2019, 02:19:47 AM »
Interesting that the junction stays brass.
Well see how well the plating goes.
Thanks, once again, for your input.
Offline CandyAppleRed
« Reply #6 on: July 22, 2019, 06:33:40 AM »
here two more examples of rear axle brake hose I removed from my cars.
The first one (with date code 07 11 6) came of a 28k miles San Jose Nov 66 S-code and the second one (date code 11 04 7) from a 45k miles Dearborn May 67 S-code.
Note that both car were fully functional and there was no leakage at the time I replaced the brake hoses. These were replaced as precautionary measure since I drive the cars.
Laurent
1967 Fastback 390 GTA Dearborn May 67 7F02S201072 (stolen)
1967 Fastback 390 GT San Jose Nov 66
« Reply #7 on: July 22, 2019, 11:05:03 AM »
You have to carefully unstake the brass junction from the bracket to properly plate.
Offline preaction
« Reply #8 on: July 22, 2019, 05:04:15 PM »
There are instances where the hose swells on the inside and either reduces or cuts off the flow of fluid I ran across this once on another make and the hose didn't appear to have any issues visually.
« Reply #9 on: July 22, 2019, 06:01:49 PM »
Blowing air through the hose will determine if a significant blockage or not . Best to do this prior to spending time on restoration.
« Reply #10 on: July 22, 2019, 06:06:22 PM »
Yeah, that was fun. But it worked! It should go back with little issue. I had never considered unstaking, but hey. I have a new skill.
As far as internal swelling, my issue was that this fitting has been sitting for many years and it's a collector of dried up brake fluid and dirt (on the body side) which was left open. A few pokes and it's clear.
