Author Topic: 67 engine comparment brake lines  (Read 1092 times)
Offline preaction
« on: March 27, 2016, 01:21:32 PM »
I had my accellarator linkage out to P&O and I found a conflict between it and a brake line that runs underneath it, it seems the brake line inter fears with the full travel of the throttle linkage Im guessing from poorly made repro brake lines. Is this how the line should be ?
« Last Edit: March 27, 2016, 01:26:20 PM by preaction »
Re: 67 engine comparment brake lines
« Reply #1 on: March 27, 2016, 06:16:24 PM »
Looks like the lower hose has been bend up and outward slightly to cause the contact
Offline preaction
« Reply #2 on: March 27, 2016, 06:53:37 PM »
Thank you Jeff, from your pics I think the bottom line is not the right one.  :(
1967 eight barrel
  • Guest
« Reply #3 on: March 27, 2016, 07:14:06 PM »
You're also missing the line hold down at the 4:00 position.
        -Keith
Offline preaction
« Reply #4 on: March 27, 2016, 07:17:18 PM »
I see that now and the hole is there too, this is much like reading a book the second time around you see things you would swear weren't there.  :o Jeff again your pics save the day !
