Author Topic: Correct style fender bolts - Sept 68 NJ  (Read 4458 times)
« on: March 26, 2016, 04:43:52 PM »
     I'd like to re-visit this post and ask the same question.  This time perhaps, with more members, might get a wider responce ?  My September 1968 Metuchen 69 Mach 1 car has no Fender bolts with the ' N ' logo, has two bolts with the ' T '  and several with the 3 small squares.  The rest are the ' anchor ' version.  I am counting 12 bolts at the fenders and another five on the radiator support wall.  Those five are; one at each fender apron to radiator support these are the ' T ' bolts, two for the hood latch and one at the oil cooler upper bracket.  Total of 17 bolts.  The Metuchen assembly line  logo and finish for these bolts ?  Thanks,  Brian
« Last Edit: March 26, 2016, 10:57:30 PM by J_Speegle »
Re: Re: Correct style fender bolts
« Reply #1 on: March 26, 2016, 10:56:29 PM »
Brian since we're/your asking about bolts over a year eariler than the original post I.m going to split the topic so we can focus on the new question and cut down on the possible confusion ;)
Re: Correct style fender bolts - Sept 68 NJ
« Reply #2 on: March 26, 2016, 11:00:03 PM »
Taken from an earlier thread - through the year. Checked an I don't have any clear pictures from that early pictures of that detail :(
Best I can do with what I currently have - hope it helps
9T02H123237 looks like "T"
9T02R149360 - no idea maybe an "N"
9F01F155672 - looks like "anchor"
9T02H202310 looks like an "N"
9T02R204327 looks like an "N"
« Last Edit: March 26, 2016, 11:33:24 PM by J_Speegle »
« Reply #3 on: March 27, 2016, 12:03:10 AM »
The "T" is the symbol for a Grade 5.1 bolt. Sometime in the late 60's, the markings for Grade 5 bolts was changed. The old style was three "bars" equally spaced at 120 degrees on the head. The newer style had an inverted "T" normally used to indicate a size smaller than 3/8 inch diameter and with a new set of strength criteria. Larger than 3/8 kept the old style and its own criteria. There was some overlap in the size vs grade. All you need to know is that it exists and it means Grade 5.1. The vendor marking appeared in the center of the "T", or on top (bottom) of Grade 5.1, and in the center of the old Grade 5.
All the other grades stayed the same.
Offline WT8095
  • Dave Z.
« Reply #4 on: March 27, 2016, 02:23:38 PM »
The "T" is grade 5.1 as you stated - it is distinct from grade 5. The "T" was only used on SEMS (screw and washer assemblies). Grade 5 did not change, it had and still has the 3 x 30 degree hash marks.
Updated to show revision and date of SAE documents. Originally posted the table from the 1971 revision. Added corresponding table from the 1967 revision.
« Last Edit: March 27, 2016, 06:52:03 PM by WT8095 »
Dave Z.
« Reply #5 on: March 27, 2016, 03:01:25 PM »
You are correct about the 5 and 5.1 standards as they exist today. In the late 60's, early 70's time period, the standards were different.
Offline Sean C. Gearty
  • 1969 San Jose GT
« Reply #6 on: March 28, 2016, 09:02:57 PM »
I purchased from the original family an October 31, 1968 built 9T01H128028. The top of the fenders have "T" on the head of the bolts, and the verticle fender bolts that anchor to the radiator support have an N on the head of the bolts.
corrected
« Last Edit: March 29, 2016, 07:03:47 AM by Sean C. Gearty »
« Reply #7 on: March 28, 2016, 10:34:29 PM »
I purchased from the original family an October 31, 1968 built 8T01H128028. ...
Sean - either the date or the first number (8) of the VIN appears off ;)
« Reply #8 on: March 29, 2016, 08:44:39 PM »
Jeff's picture and Sean seem to agree on the ' T ' bolt on the fender tops ?  Sean did not mention what bolt he has on the shock towers ?  No agreement on the firewall bolts so it's not looking good so far.  My car seems to have an assortment with no way to verify ?  Maybe some more replies/observations ?  Is the ' T ' Grade 5.1 bolt factory installed ?   Brian
« Reply #9 on: March 31, 2016, 07:08:00 PM »
Any help with what the correct finish would be for the fender bolts ?  Yellow Dichromate, Black Phosphate, Bright Zinc or other ?  Thanks,  Brian
« Reply #10 on: March 31, 2016, 10:53:30 PM »
Believe from the ones I've seen bright/clear/silver zinc (what ever your local platter chooses to call it seems to be the practice
Offline Anghelrestorations
    • Anghel Restorations
« Reply #11 on: April 01, 2016, 01:37:45 AM »
The fender bolts I think are actually a cadmium finish.  I just had 100 of them redone and they came out great.  Slightly different look than the zinc finish.
Marcus Anghel
www.anghelrestorations.com
« Reply #12 on: April 01, 2016, 02:21:49 AM »
Easy enough to test - just have to dig out the recipe :)
« Reply #13 on: April 01, 2016, 02:32:39 AM »
Ahhh yes, the recipe.
Marcus Anghel
« Reply #14 on: April 01, 2016, 08:25:19 AM »
So are we talking two entirely different colors here.  Bright/clear/silver zinc vs Cadmium.  I assume cadmium is a gold color ?  Marcus do you have any input for the correct  bolt head logo for a East Coast car ?  Thanks, Brian
