Author Topic: Safety convenience panel lens. Anyone change a set with the Drake Repos?  (Read 1670 times)
1967 eight barrel
  • Guest
How do you re-assemble the lamps once you remove the old bezel, epoxy?
        -Keith
        -Keith
Yes, I have changed mine. It was a few years back now but a few things come to mind.
1.) the chromed bezels look to be an exact match
2.) the lenses are a VERY GOOD match on three of the four lenses but ONLY FOR THE LATER VERSION USED for late 67-68 (the "SEAT" lens was completely wrong, originals were "BELT")
Be careful applying pressure in attempting to get the "tube" snapped into the bezel. The tube bends very easily and the lamp will not fit as it should. I didn't think I had bent mine but I had a little. Difficult to straighten them.
YES, I used epoxy. I believe it was JB Weld and I used a toothpick to minimize mess.
« Last Edit: March 25, 2016, 06:55:12 AM by 67gtasanjose »
1967 eight barrel
  • Guest
I noted the originals are probably swaged on. I got them off, but as you had done, I bent the lip just slightly on the tube. I didn't check the material the tube is, but perhaps it's aluminum. Thanks for the input.
        -Keith
        -Keith
Zinc plated steel actually, it's just very thin
1967 eight barrel
  • Guest
So you simply lined up the notch and JB welded them in?
        -Keith
        -Keith
I found a way to clamp them in as it cured, not sure what I did to clamp them but remember doing so
1967 eight barrel
  • Guest
I will use plastic pressure clamps. Thanks, Keith
