Author Topic: '67 radio installation with console  (Read 3090 times)
Offline socalgt
« on: March 24, 2016, 10:13:59 PM »
What is the easiest sequence of installation of the radio and console.....is the radio attached to the console and then the console slid into position and the radio bracket then attached underneath the dash?  Currently the radio mounting bracket is attached under the dash, but not to the console and the original am/8 track is out of the car....and I'd like to install the radio as easily as possible.
« Last Edit: March 24, 2016, 10:32:52 PM by socalgt »
Offline socalgt
Re: '67 radio installation with console
« Reply #1 on: March 25, 2016, 12:39:38 AM »
I see now that the top portion(face plate) of the console is a separate piece...so I'll assume I mount the radio to the bracket already in place under the dash, attach the face plate and then the console itself, in that order?
« Reply #2 on: March 25, 2016, 07:40:38 AM »
Maybe others have better ideas, but here is how I do them.
Radio sits in dash attached to the front console bracketing using the rear support stud on the radio, so yes, the radio will be already in place. The console is fully assembled except the shifter plate (same manual or auto trans), shifter should be out of park, in neutral or drive (auto) or directed rearwards on manual trans. Point the back of the console towards the headliner while the front of the console towards the gap or area ahead of the shifter. As you enter the nose of the console downwards and going up under the dash, swing the back of the console towards the floor some. Watch the shifter handle as it enters. You may need to adjust it some as you move or swing things together. ALSO, be sure and watch both dash front brackets as they get nearer to the console (all of this is happening simultaneously, hard but not impossible) Those brackets hanging up from under the dash, need to stay INSIDE of the console but also need to get "inside" of the compartment of the console.(the compartment behind the roll up door) The console should now be about an inch or two from being against the dash, pretty much in place as you feed the radio tuning shafts into the console face. These last two details are part of the difficulty, you are trying to get or keep those two forward brackets INSIDE of the console compartment (read as past the very back of the compartment) about the same time with feeding the tuner shafts into place. Just don't hurry it. The shifter is probably fighting you around the shifter opening too at this point, if the handle is off the shifter, it may be a bit easier (auto trans) but not required. Once the console is all the way against the dash and in place, it may be easier to locate screw holes with a fine steel "pick". start screws at the top of radio plate, probably the front two under the carpeting next and the back two last. The screws under the carpeting were punched in on the assembly line so with different or new carpeting, often difficult to locate them again. This same "pick" tool has worked for me in doing this each time. DO NOT OVERTIGHTEN THE SCREWS ON THE CONSOLE to the floor. (ask me how I know this ;) )
Radio nuts & washers can be tough to start without cross threading. I use a small pocket screw driver or the likes and if they will not spin freely, they may be cross threaded...be careful not to over tighten them.
The shifter plate goes on last after everyting else is secured. Protect the leading edge of the rear console top behind the shifter plate opening ( I would use tape). You will need to also protect the face edge of the lower corners near the compartment opening from scratching too (I would use tape there also). Notice on the under side of your console shifter plate, there should be a wavey spring plate on the back, staked onto the shifter plate. You are going to set the shifter plate into place and to get the shifter plate under the radio face plate of the console, you slide the shifter plate back over top of the rear console plate by lifting a little against that spring plate, so the shifter plate ends up over top of the rear console trim plate temporarily (hence the protective tape). Now simply slide the shifter plate under the radio face plate and remove your protective tape.
Key element here is to not scratch things up in the process. I've had mine in and out several times and also on various other 67-68 Mustangs or Cougars over the years.They were driver cars so I got a little "practice", at times learning by mistakes while doing various radio swaps, carpeting replacements, shifter light bulb replacement, dash repainting and so on...I'd say I've done this at least 20 times. (maybe more?)
« Last Edit: March 25, 2016, 07:54:09 AM by 67gtasanjose »
Offline socalgt
« Reply #3 on: March 25, 2016, 10:48:55 AM »
Thanks for all the tips....I figured it was not an easy process.  I will certainly make sure the radio is working properly before installation, as it looks like something you  don't want to have to do twice.
Offline socalgt
« Reply #4 on: March 25, 2016, 04:00:05 PM »
I probably wasn't clear on exact position in the console/radio installation....My console was already installed, so I removed the upper section that fits over the radio.  I was then able to install the radio without removing any thing else and then put the upper section back on.  Unfortunately, the PO was not interested in properly disconnecting wires during the restoration, so I have to figure out what goes where.  The power wire is marked on the radio as well as the ground and the three prong(1 female)plug appears in tact, which I assume goes to the door speakers.  I can't as of yet find the other half of it to connect it, so I'll check the wiring diagram. ( I assume it is a matching three prong connector)   Attached is a pic of the connector from the radio.
« Reply #5 on: March 25, 2016, 11:28:01 PM »
The three prong connector is the speaker wire it connects to a wire that runs to the RH and LH door speaker wire that connects under the kick panels.  I just purchased one from Pete Disher the corral snake for a project I am working on.
Offline socalgt
« Reply #6 on: March 26, 2016, 03:17:00 PM »
Thanks.....I ordered the harness that attaches to the connector and splits to the door speakers also.  In addition to this harness, there are two wires from the radio...one marked 12 volts(yellow w/black stripe) and the other(blue w/black stripe) marked ground.  I assume the 12 volt wire also supplies power to the radio light?
« Reply #7 on: March 26, 2016, 03:42:44 PM »
yellow/black is accessory/radio 12v supply
blue/black IS NOT A GROUND, it is instrument lamp supply to radio light (dims with dash lights)
Offline socalgt
« Reply #8 on: March 26, 2016, 07:26:28 PM »
Glad I asked...someone put a tag marked GND, which I assumed to be GROUND.
Offline socalgt
« Reply #9 on: March 26, 2016, 07:34:18 PM »
I found a two wire connector/plug( yellow w/black stripe....blue with red?...hard to tell) that looks like it should attach to the two wires from the radio, which I assume were originally in a connector/plug also...I believe the am 8 track wiring diagram indicates this also.
Offline socalgt
« Reply #10 on: March 26, 2016, 08:24:13 PM »
...blue w/red stripe it is....so I will connect them to the two wires coming out of the radio....(still don't understand why so many people just cut wires that could easily be disconnected and their connections kept in tact)
« Reply #11 on: March 26, 2016, 09:26:24 PM »
I found on the wiring harness side 2 blue with red wires, and one yellow with a black tracer. On the radio side has the two male bullet connectors
« Last Edit: March 26, 2016, 09:30:42 PM by 67gtasanjose »
