Author Topic: 67 390 ca emmissions heater hose routing  (Read 1081 times)
Offline mach1one
« on: March 21, 2016, 02:24:54 PM »
Looks awfully tight in the right bank of my 67 390 4sp ps Ca emmissions San Jose BD 5/67 What was the factory routing of the heater hoses with all the Ca emmissions in the way. Where special bent hoses used for this . Any photos ? thanks Lu
Re: 67 390 ca emmissions heater hose routing
« Reply #1 on: March 21, 2016, 03:59:35 PM »
They weren't on the 67 Shelby so it would be my guess not on regular Mustang ether but others may know better. I hope to see you in a couple weeks in Columbus.
Offline mach1one
« Reply #2 on: March 21, 2016, 11:01:06 PM »
Bob, I hope to see you  in Columbus . This Ca emmissions setup is something else. I'm hopping a forum member may have a original shot of the heater hose setup.
« Reply #3 on: March 21, 2016, 11:40:13 PM »
Take it that you don't have AC.  If not would agree that straight - not preformed heater hoses were used. Have seen original hoses routed down the valley between the passenger side valve cover and the same side of the intake manifold. On small blocks I've found them woven to keep them together with all the other hoses running back to the check valve but can't confirm that with the big block applications
« Last Edit: March 21, 2016, 11:45:38 PM by J_Speegle »
