Author Topic: Correct original water pump for 289  (Read 1556 times)
Offline DKutz
« on: March 16, 2016, 10:52:07 PM »
So I am about to replace the water pump on my car.  Although I am not too concerned with correctness on the replacement, I don't want to throw out the old one if it something that is original and hard to find. So...
How can I id an original water pump?  Part number?  Date codes?  Stamps etc?
If it's just a repop it goes in trash
Offline ChrisV289
Re: Correct original water pump for 289
« Reply #1 on: March 17, 2016, 12:41:22 AM »
There should be an engineering number, C5OE-8505-C.  Date code should be for your car a 64 in circle with dots indicating the month.  I think probably around August or so depending on when the engine was assembled which should be the date code near the driver side head towards the front...Should also be an aluminum water pump as opposed to a cast iron pump
2009 V6 Mustang Coupe
Offline DKutz
« Reply #2 on: March 17, 2016, 03:09:23 PM »
guess mine has been changed at some point then, its not aluminum...
Offline ChrisV289
« Reply #3 on: March 17, 2016, 03:58:29 PM »
your timing cover was probably changed too as they are different
Offline DKutz
« Reply #4 on: March 17, 2016, 03:59:26 PM »
yuup
