Author Topic: Wanted 289 hipo exhaust manifolds  (Read 1458 times)
Offline rcombs
« on: March 15, 2016, 02:15:20 PM »
I am looking for a set of hipo exhaust manifolds for my k code. I would prefer originals ones since the reproduction ones have some fitment issues. My question is how to tell originals for the reproduction ones?
Rick
« Last Edit: March 15, 2016, 06:42:31 PM by J_Speegle »
Offline sgl66
Re: Wanted 289 hipo exhaust manifolds
« Reply #1 on: March 15, 2016, 09:43:43 PM »
Originals have date codes under the part number. Some repos do not have a date. Scott Drake makes one that does however the date font size is incorrect on the SD. There a couple pictures of originals in this site if you search for "hipo exhaust". When you find them, compare to the SD version and it will be obvious.
Edit: here it is http://www.concoursmustang.com/forum/index.php?topic=6447.msg36483#msg36483
« Last Edit: March 15, 2016, 11:34:21 PM by sgibbs »
« Reply #2 on: March 15, 2016, 11:32:21 PM »
I have to loosen my originals to insert number 4 and number 8 plugs.
Offline rcombs
« Reply #3 on: March 16, 2016, 03:55:09 PM »
Thanks for the info. I see what you mean about the SD date code. I'm looking at a set on ebay http://www.ebay.com/itm/331803089551?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT. They look to be original but from 1964 if I'm reading the code right. I have a mid year 1966.
Rick
Offline 5F08KGT
« Reply #4 on: March 20, 2016, 10:22:51 AM »
I did too Jim, but then someone suggested using a cheap, thin socket/wrench made for lawnmower engines which I have and it seems to work fine w/o loosening my manifolds.....
« Reply #5 on: March 20, 2016, 12:46:00 PM »
- someone suggested using a cheap, thin socket/wrench made for lawnmower engines which I have and it seems to work fine w/o loosening my manifolds.....
There are not too many 13/16 hex lawnmower sparkplugs so the "el cheapo" sockets are also in short supply. I frequented swap meets and flee markets looking and hoping for one. Everyone wants "quality" so the cheap, thin wall sockets are rare.
