Author Topic: Clutch linkage and pivots. What finish?  (Read 3979 times)
1967 eight barrel
  • Guest
« on: March 15, 2016, 01:33:54 PM »
What finish should be the clutch pivot frame bracket, bell crank and clutch pushrod be? The NOS engine pivot I have is zinc.
« Last Edit: March 18, 2016, 12:43:27 AM by 1967 eight barrel »
1967 eight barrel
  • Guest
Re: Clutch linkage and pivots. What finish?
« Reply #1 on: March 18, 2016, 12:44:05 AM »
bump... Jeff,  Bob????
« Reply #2 on: March 18, 2016, 01:36:27 AM »
Bare steel originally on the assemblyline. Same with the Z bar.
1967 eight barrel
  • Guest
« Reply #3 on: March 18, 2016, 04:02:16 AM »
What would best replicate the finish? Gray, silver, cast metal?
« Reply #4 on: March 18, 2016, 08:38:13 AM »
I would clean it with Evaporust and coat it in T9 to preserve it.
« Reply #5 on: March 18, 2016, 12:41:44 PM »
+1  except cleaning it would involve taking the zinc plating off by a acid bath . If blasing i would tumble in a apropriate meda to bring the metal back to proper appearance and then " coat it in T9 to preserve it." I would not paint it because the paint will fail where bolts go through and at pivot points .
1967 eight barrel
  • Guest
« Reply #6 on: March 18, 2016, 04:34:33 PM »
That was my concern, durability long term. It seems all Ford service replacements are zinc plated, as well as the reproductions. Most of the reproductions don't have a welded pivot pin on the frame side either. Thanks for the information.
        -Keith
« Reply #7 on: March 18, 2016, 05:26:17 PM »
        -Keith
The Ford service versions changed to zinc plated in 1970 also.The repro market typically wrongly assumes that the last service replacement is good enough .
« Reply #8 on: March 19, 2016, 12:05:37 PM »
1967 eight barrel  first I would make sure you have the CORRECT 67-68  vs 69-70 Z-bar brackets as in your first post you said you had a nos zinc frame side bracket & the only zinc plated ones I seen were service replacements from late 70s-80s era as ford sold the 69-70 type to replace the 67-68 type after 69.  I have never seen nos 67-68 brackets unless they were ordered back in 67-68. I pointed this out years ago to some 67 Shelby guys & they never noticed the difference & the MPC calls the change out but never changed the # to a c9zz instead still used the (frame side) c7zz-7507-a & changed it to a - b & (block side) c7zz-7a572-a & changed it to a -b also. The brackets are same design but the adjustment holes changed from 67-68 to 69-70 FE engines. The 67-68 had round hole on frame side & slotted adjustment on the block side vs 69-70 frame side slotted adjustment & block side round hole. So you need to pair them up to be correct & the 67-68 versions are harder to find.      Marty I agree with you on the evaporust cleaning as you can save original plating & metal finnishs   (depending on the condition they are in) by soaking part in older used weaker evaporust & don't let the part soak TOO long & when you remove part wash off with water then dry & oil.   When you first remove the part from soaking DONT rub the part with anything as you will remove the plating just water rinse part off & if part isn't clean enough resoak part longer. We use this method when cleaning parts for survivor cars but had some parts clean-up good enough that didn't need replated.
1967 eight barrel
  • Guest
« Reply #9 on: March 19, 2016, 08:53:17 PM »
Well, I definitely have the service replacement, being the adjusting slots are oval, (left to right.) I noted the cheap over seas reproductions coming in are just pressed in and not welded. There is a LOT of pressure on those pivots, and I see the splined pressed in pivot stud wearing quickly on vehicles driven more often.
        -Keith
« Reply #10 on: March 20, 2016, 04:05:02 PM »
kieth are you doing a concours resto as I have some 67 brackets in my inventory ?
1967 eight barrel
  • Guest
« Reply #11 on: March 20, 2016, 05:23:23 PM »
Ed, for the most part, yes.
                                    -Keith
« Reply #12 on: March 20, 2016, 06:30:17 PM »
are both of your brackets 69-70 as we know the nos service frame one is?
1967 eight barrel
  • Guest
« Reply #13 on: March 20, 2016, 06:45:22 PM »
Ed,
I don't know the difference on the block side. As a matter of fact I wasn't aware there was any difference until Bob had mentioned it.  Pictures would be helpful.
        -Keith
« Reply #14 on: March 20, 2016, 08:01:37 PM »
Ed,
        -Keith
I took a quick picture. Of course the chassis side is not adjustable like the 6970 version.
