Author Topic: Voltage regulator  (Read 2962 times)
Offline rocnhrse
Voltage regulator
« on: March 14, 2016, 11:15:26 PM »
67 s code gta April San Jose  no a/c what  would be the proper  voltage  regulator  for this application ?
67 mustang  GTA  S code fastback  San Jose  April 67
Re: Voltage regulator
« Reply #1 on: March 15, 2016, 12:24:05 AM »
Typically C5AF silver stamp.
Offline rocnhrse
« Reply #2 on: March 15, 2016, 09:05:40 AM »
Thanks Bob,you are a wealth  of accurate  info
Offline Ralf
« Reply #3 on: March 15, 2016, 09:09:01 AM »
My investigation says, gold stamped when it is with A/C.
But could be a difference in built plant and built date as well.
Mine is San Jose 11/30/66 with AC.
Ralf
« Reply #4 on: March 15, 2016, 10:03:25 AM »
I might have a NIB repro voltage regulator, Silver stamping, older design without the larger cut-out many repro's today have.
Message me if interested
« Reply #5 on: March 15, 2016, 06:35:20 PM »
Never seen a gold FoMoCo or Autolite stamped regulator any plant or year.
Might you be seeing yellow?
Have seen some Motorcraft that were sort of orange/goldish
« Last Edit: March 15, 2016, 06:41:26 PM by J_Speegle »
« Reply #6 on: March 15, 2016, 06:43:24 PM »
Ralf
C5TF is yellow stamp which is what you are probably referring to. It has a different capacity then C5AF silver stamp . C5TF is Typically paired with 55amp alt and also common service replacement .
Offline preaction
« Reply #7 on: March 15, 2016, 08:32:54 PM »
Is my experience unique or are the reproduction regulators unreliable ?
Offline Ralf
« Reply #8 on: March 16, 2016, 04:11:11 AM »
WCCC:
Mustang 1967
Voltage Regulator w- Air Conditioning - Repro
http://www2.cougarpartscatalog.com/c5tf-10316-a.html
Voltage Regulator COVER Only w- Air Conditioning - Repro
http://www2.cougarpartscatalog.com/c5tf-cover.html
May be WCCC is wrong here?
« Last Edit: March 16, 2016, 04:17:14 AM by Ralf »
« Reply #9 on: March 16, 2016, 07:24:56 AM »
I've read this is true (in other threads).
This is yet another sad disappointment.
Keep a spare electronic one available & a nut driver to change it out as needed...keeping the repro available as "show only"  >:(      ...just like the battery issue  >:(
Offline BKnapp
« Reply #10 on: March 16, 2016, 10:02:15 AM »
Has anyone tried Kevin's reproduction at martiauto.com?
http://www.martiauto.com/itemselection.cfm?item=VR-3&selecteditem=yes
« Reply #11 on: March 16, 2016, 10:03:45 AM »
i believe that is where the other vendors are sourcing them so no difference.
