Author Topic: 67 San Jose Dust sheild/Caliper bracket bolt orientation  (Read 2494 times)
Offline bhoulis
  • 67 GT350
« on: March 13, 2016, 06:45:32 PM »
What is the proper orientation of the mounting bolts for the caliper bracket/dust shield assembly, bolt heads on the dust shield side or vise versa? From what I can tell from shop and Osborn manuals it looks like nuts go on shield side but I see alot of the other way when doing a web search for pics. Any help is much appreciated. Brian
« Last Edit: March 13, 2016, 09:27:23 PM by carlite65 »
Re: 67 San Jose Dust shiled/Caliper bracket bolt orientation
« Reply #1 on: March 13, 2016, 06:55:32 PM »
In this particular case trust the assembly manual illustration instead of what you found on your web search.
« Last Edit: March 13, 2016, 07:36:48 PM by J_Speegle »
Offline bhoulis
  • 67 GT350
« Reply #2 on: March 13, 2016, 07:08:21 PM »
Thanks Bob. The illustration in my assembly manual isn't too clear so I went with what the shop manual shows which is nuts on the dust shield side. Not sure if the shop manual should be used as a definitive source. Just want to check with the experts and those who have more experience than me. Brian
« Last Edit: March 13, 2016, 07:37:00 PM by J_Speegle »
« Reply #3 on: March 13, 2016, 07:10:10 PM »
First welcome to the site hope you find all your concours related questions answered here
Why don't you post your cars info and we can just provide a picture of what they were doing at the same plant and time as when your car was built?
You'll find attaching/listing your cars info in your signature a time saver over the long and even, short run as we'll need it often when respondign to your questions
« Last Edit: March 13, 2016, 07:36:39 PM by J_Speegle »
Offline bhoulis
  • 67 GT350
« Reply #4 on: March 13, 2016, 07:13:31 PM »
Yes, I will do that. It's a 67 GT350  3-22-67 build. Brian
« Last Edit: March 13, 2016, 07:36:30 PM by J_Speegle »
« Reply #5 on: March 13, 2016, 07:35:41 PM »
Just noticed that the thread is titled for the caliper bolts though it appears that the focus is on the four dust shield/spindle bolts
Here is a shot of two of those bolts/nuts and the caliper to spindle bolts  that should help. Last time or before, the caliper bolt safety wires were not replaced
Offline bhoulis
  • 67 GT350
« Reply #6 on: March 13, 2016, 08:36:47 PM »
Interesting. I've been searching pics on the web that look like unrestored or original ( rusty, dirty, greasy ) and can find them both ways. Could it be a plant specific thing or line worker doing it the easier way? Would be interested to hear from others. Shop manual definitely shows nuts on dust shied side and from what I can see, so does the assembly manual. Brian
« Reply #7 on: March 13, 2016, 08:59:39 PM »
I don't know about other plants but SJ was typically as the assembly manual. I suspect the same for the others .
« Reply #8 on: March 13, 2016, 11:56:18 PM »
That is the way I've found 67 San Jose examples
Offline bhoulis
  • 67 GT350
Re: 67 San Jose Dust sheild/Caliper bracket bolt orientation
« Reply #9 on: March 14, 2016, 07:24:07 AM »
Which way? Like the picture you posted or as per the manual?? Brian
« Reply #10 on: March 14, 2016, 02:53:19 PM »
Like the original car posted in the picture I show above.
Offline bhoulis
  • 67 GT350
« Reply #11 on: March 14, 2016, 11:34:41 PM »
Thanks Jeff. Brian
