Author Topic: Interior Quarter Trim Screws  (Read 4849 times)
Offline alanmac
Re: Interior Quarter Trim Screws
« Reply #15 on: June 21, 2023, 01:26:13 PM »
Updated! I came to the conclusion that many of my interior screws were not correct. I fixed the fiberglass interior trim screw holes where needed.  Painted the trim pieces with the correct paint from NPD.  I installed the correct AMK fastener kit.  I wouldn't have noticed the flaws without this tread bringing it to my attention.  Thanks for all the information. Alan
« Last Edit: July 04, 2023, 04:14:44 PM by alanmac »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
Offline hopey
« Reply #16 on: June 22, 2023, 09:53:44 AM »
Attached is a picture of the screws on my Metuchen built car.  The upper screw is a Philips pan head screw zinc plated.  The hole on the upper screw is worn from removal but the drivers side is clearly not countersunk. The lower countersunk screw is per the assembly drawing.  Alan
The S9 zinc finish is what I have observed, but my enquiry was regarding the S2 finish on dark interiors. Has anyone observed this from any plant on unrestored examples?
1970 BOSS 302
Built 11/15/69 Dearborn
« Reply #17 on: June 22, 2023, 05:54:00 PM »
Looking at the pictures I have of 70's from all plants and across the year while trying to focus more on the black interior cars, did not find any examples that support a P 7 O finish used on the 70 interior trim panel retaining screws on Mustangs
Offline hopey
« Reply #18 on: June 22, 2023, 07:10:54 PM »
Jeff, thanks for looking.
1970 BOSS 302
« Reply #19 on: June 22, 2023, 07:59:18 PM »
Let me be the devils' advocate.
If a 70 Mustang Sportsroof, or Mach I, with a dark interior, showed up at a MCA judged car show, with the referenced screws having a phosphate and oil treatment, as noted in the 1970 Mustang Interior Assembly Manual, what would you do? Do you have documentation to the contrary? How about the Thoroughbred class?
Offline hopey
« Reply #20 on: June 22, 2023, 08:09:43 PM »
Depends if it was a fixed or sports deck rear seat going by the generally available published assembly drawings Jim 😜
Seriously though that is part of the reason I am researching this. A friend of mine had a points deduction in concours trailered for having S2 P&O finish screws on a January 1970 Dearborn built Boss 302 with dark Ivy interior.
1970 BOSS 302
« Reply #21 on: June 23, 2023, 10:33:34 PM »
Thought I would post some examples I found on unrestored cars with back interiors from 70 production. From approx 0F12xxxx-0F19xxxx
Since Hopey brought up Jan 70 green interiors will look and post similar cars to try and help that specific focus. Going to be the same though
« Reply #22 on: June 24, 2023, 12:31:03 AM »
70 Green interior examples. As close as I currently have
Early Dearborn car. Likely built around Mid Sept 69
Nov 17th NJ built car.
« Reply #23 on: June 24, 2023, 12:58:40 AM »
The question still remains. Where is the documentation authorizing the substitution of -S9 screws for -S2 screws?
Offline hopey
« Reply #24 on: June 24, 2023, 07:33:59 PM »
Jim,
The 11/14/69 revision of the assembly manual dwg # TO-525 (attached again) is the only reference I have found to S2 finish screws being used on dark interiors, supported of course by the availability of said same reproduction fastener kit from AMK.
However from the photographic evidence Jeff has kindly provided it seems that originals were exclusively S9 - with no S2 production fasteners documented so far.
Jeff,
Thanks for checking.
1970 BOSS 302
« Reply #25 on: June 24, 2023, 08:00:20 PM »
One. More Time.
If you submit a 70 Mustang, with a dark interior option and all the other "things", to be judged in the Thoroughbred class, with -S2 finish instead of the -S9, and it is rejected - what are the justifications? It there a TSB? Do you have a copy of an assembly line waiver?
I am posing a deep, dark quandary. Are "pictures" enough? Should this "quirk" be spelled out in MCA rules?
