Author Topic: 67 gt 350 brake booster line  (Read 3608 times)
Offline Brian in PA
« on: March 13, 2016, 01:33:26 PM »
Was the factory steel used from the manifold to the rubber hose to the brake booster?  Or was this changes at Shelby?  Thanks
Ps any pics?
Thanks Brian.
Re: 67 gt 350 brake booster line
« Reply #1 on: March 13, 2016, 06:40:27 PM »
Hope these help
« Reply #2 on: March 13, 2016, 06:51:48 PM »
Ps any pics?
Thanks Brian.
To add -it is important in understanding some off the process's for the conversion that the aluminum intake was installed on the engine as  (oil pressure line installed at SA) at the Ford engine plant and then installed on the SJ assemblyline like any other Mustang.  SA got Ford to do a lot for cost saving reasons. About the only thing that SA had to install engine related was the SW oil pressure line (and things related to that installation)regardless of if GT350 or GT500.
Offline Brian in PA
« Reply #3 on: March 13, 2016, 09:01:56 PM »
Thanks fellas!  It looks like some inconsistent lines too.  Maybe what was laying around or just hand made to fit application?
« Reply #4 on: March 13, 2016, 09:15:26 PM »
Mostly consistent.  Inconsistency in this case would be more likely attributed to PO handling of metal line more so then a Ford difference IMO.
Offline Brian in PA
« Reply #5 on: March 13, 2016, 10:29:16 PM »
Ya good point Bob. It looks like the 428 line from MU will do the job.
« Reply #6 on: March 13, 2016, 11:22:58 PM »
It is not the 428 line.  It was the same vacuum tube used on the 67 289 cast iron intake with power booster.
Offline Brian in PA
« Reply #7 on: March 14, 2016, 12:00:00 AM »
Here lies my confusion. I got one from NPD that is for a 67 289 it looks like an S shape. On their website the 428 one looks like the piece in Jeffs pics. Unless I missed something. Thanks for your patients Bob.  :D
« Reply #8 on: March 14, 2016, 12:05:33 AM »
Yes repo pieces verses originals - what could go wrong. Agree that the visual difference in one in pictures are most likely from a heavy hand at some point - especially #3  ::) was using that more to show the attachment to the intake fitting
« Reply #9 on: March 14, 2016, 12:18:48 AM »
I feel your frustration. I can only tell what is correct but sorry in this case can't tell you what company is going to be knowledgeable enough to sell you the correct piece. As the pictures shows it is more a simple "L" shape more so then anything else.
Offline Brian in PA
« Reply #10 on: March 14, 2016, 07:46:53 AM »
Well said guys. I'll get the one that looks right regardless of what it says it's for. Thanks again for the time and pics!
