Author Topic: '66 gt steering box on manual vs. power steering  (Read 998 times)
Offline socalgt
« on: March 09, 2016, 03:30:16 PM »
Does the original steering box on a '66 GT with manual steering need to be replaced in order to convert to power steering?
Re: '66 gt steering box on manual vs. power steering
« Reply #1 on: March 09, 2016, 04:20:23 PM »
Mechanically they are the same. The difference is in the "preload". It's covered in the service manual. If it's a do-it-yourself project I don't know.
« Reply #2 on: March 09, 2016, 08:39:16 PM »
I would classify it as a DIY task.  The only not so common tool is a torque wrench that measures well in the 6-10 inch-pound range.  I found that a beam style is what is needed.  There are 0-60 in-lb beam styles available for about $30.  Seems to me that a 3/4" or 11/16" 12 point socket fit over the shaft, so you need adapters to convert from the 1/4" drive up to 3/8" or 1/2" matching the socket.
Good instructions on http://www.stangerssite.com/adjustment.html
