Author Topic: Starter #s  (Read 1795 times)
Offline 66427
Starter #s
« on: March 09, 2016, 11:50:51 AM »
New here guys
 I'm doing a 68 and would like to know if the numbers on my starter are correct before I have it redone
My car is a mid feb 302 Hertz car
Here's the numbers
         Autolite.  12V.  JSA
  DOAE.  11001. B.    OA8C
Is the date code. OA8C=A January.  8=year. And C=3rd week
Dave
Re: Starter #s
« Reply #1 on: March 09, 2016, 12:18:54 PM »
New here guys
Here's the numbers
         Autolite.  12V.  JSA
Dave
That is a 1970+ stamped cast Ford number. The date is January 8, 1970, and 3rd week or 3rd shift.
« Last Edit: March 09, 2016, 05:04:05 PM by krelboyne »
Re: Starter #s
« Reply #2 on: March 09, 2016, 01:12:08 PM »
Picked up this C7AF starter from 7F01C129xxx    Clearly mechanically stamped, no ink stamp.  Black paint still on it.  I suppose an ink stamp may have washed off.  But the stamp is there.
Re: Starter #s
« Reply #3 on: March 09, 2016, 01:28:12 PM »
It would be ether metal stamped with the engineering number or ink stamped on the starter. Not both. 67 was the transition year for this .Ink early ,metal stamp later in the production year.
« Last Edit: March 09, 2016, 01:30:31 PM by Bob Gaines »
Offline 66427
Re: Starter #s
« Reply #4 on: March 09, 2016, 02:58:31 PM »
Ok
So what numbers do I look for on a starter.
Car is mid February 68......... So a date like this 8A8C
Which would be a 68 jan 8th
What about a casting number?
Appreciate all help
Dave
Re: Starter #s
« Reply #5 on: March 09, 2016, 04:48:41 PM »
So small block automatic application. The picture below is an example of what your looking for though date is from one a few months later that your likely was
No "casting " number but as described there are engineering numbers stamped in the main case or ink stamped depending on application and supply it appears
http://www.concoursmustang.com/forum/index.php?topic=7197.new#new
Other earlier threads that the search feature turned up ;)
http://www.concoursmustang.com/forum/index.php?topic=11458.msg68854#msg68854
http://www.concoursmustang.com/forum/index.php?topic=9894.msg59369#msg59369
http://www.concoursmustang.com/forum/index.php?topic=11000.msg66530#msg66530
http://www.concoursmustang.com/forum/index.php?topic=7197.msg40705#msg40705
« Last Edit: March 28, 2019, 05:42:23 PM by J_Speegle »
Offline 66427
Re: Starter #s
« Reply #6 on: March 09, 2016, 07:31:51 PM »
A recommendation on a vendor that may stock cores with various dates?
Dave
Re: Starter #s
« Reply #7 on: March 11, 2016, 05:40:22 PM »
Dave
Haven't done it before but you might want to try calling  Bob Antounian at CAE, Inc. Quality Remanufactured Starters & Alternators in Van Nuys, California. They also sell rebuilt units on EBay and normally show stamping details with dates
Re: Starter #s
« Reply #8 on: May 28, 2016, 05:33:26 PM »
They also go by the name of bnrpart on e-bay. There's a write up here -
http://www.concoursmustang.com/forum/index.php?topic=11741.msg71520#msg71520
