Author Topic: 69 Boss 429 headlamps  (Read 5533 times)
Offline bgp429
« on: March 06, 2016, 07:21:36 PM »
Trying to figure out what headlamp was installed. Has a 2-28 69 build date at Ford.   I think it should have a TS with Ford script. Is that correct? If so does anyone make a new replacement? Tried the search feature, it didn't exactly pin it down.
Re: 69 Boss 429 headlamps
« Reply #1 on: March 06, 2016, 09:27:58 PM »
TS is typical according to Ed Meyer. Only old replacement.
« Reply #2 on: March 06, 2016, 10:55:27 PM »
ts then ge started showing up in may 69 or so  & I got more ge than ts
Offline bgp429
« Reply #3 on: March 06, 2016, 11:15:16 PM »
Saw the Ed Meyer video with the red boss. He brought up the lamps but it was an earlier car than mine.  Didn't know when the GE change over began. Now the search begins. Thanks
« Reply #4 on: March 06, 2016, 11:17:42 PM »
That shouldn't take long if you contact Ed.As he said he has both. To sell!!  ;)
Offline bgp429
« Reply #5 on: March 07, 2016, 10:33:23 AM »
Actually it was easier than I thought. Found 3 on E Bay and one in the basement. Cost about $50.
« Reply #6 on: March 08, 2016, 11:10:13 AM »
main thing to watch for is the old style wide fluting glass that ended around 72 or so as the glass design is a very noticeale change.
« Reply #7 on: March 08, 2016, 08:14:36 PM »
Good memory Ed!  Change was published March 17, 72 change took place according to Ford on the line starting Jan 3rd of that year
TSB article info posted here ;)
http://www.concoursmustang.com/forum/index.php?topic=13239.0
« Last Edit: July 02, 2020, 06:41:54 PM by J_Speegle »
Offline bgp429
« Reply #8 on: March 08, 2016, 10:09:15 PM »
Headlamps seem like such as easy thing to get right but apparently not.
Here are 3 lights, all are TS. Low beam on the left is wide flute with script so it is wrong. Center one is narrow flute without script so it is wrong. High beam on the right is wide flute with script so it is wrong. What I need is narrow flute with script on all 4?
URL=http://s281.photobucket.com/user/bgp429/media/lamps20001_zpsaktouu1h.jpg.html][/URL]
« Reply #9 on: March 08, 2016, 11:23:23 PM »
bgp429 check the link below and it should address the width of the fluting issue
« Reply #10 on: March 09, 2016, 02:09:31 PM »
bpg   your 2 outer bulbs in your pic are correct
Offline bgp429
« Reply #11 on: March 09, 2016, 09:42:52 PM »
Thanks, I got it now. Glad the 2 outside ones are correct. Have a set of those.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #12 on: March 10, 2016, 09:33:02 AM »
I am going to add this guide in this discussion here as it may be useful so you can better see the fluting and some other details.
http://anghelrestorations.com/uploads/3/1/7/6/3176630/headlights_v1.0.pdf
Marcus Anghel
www.anghelrestorations.com
« Reply #13 on: March 10, 2016, 04:38:46 PM »
Marcus, what about the Westinghouse with the molded trademark in the glass? I have never thought that was correct for a 69/70 Dearborn Boss or Shelby but what about other Ford plants. Was the Westinghouse not used at all in 69 or 70? It seems like I have found a number of them over the years on 70 models before . Torinos and Rancheros? Maybe 71 just don"t remember. I didn't pay much attention because it was something that wasn't for the cars I was interested in.
« Reply #14 on: March 10, 2016, 10:41:28 PM »
The Westinghouse bulbs are by far the coolest of them all in my opinion.  My experience at this point is that I do not see them really used in Mustangs and Cougars during 69 and 70.  Cant say they are never used, but certainly not typical.  I was always of the opinion they were used in earlier years but I have no paid attention to the other brand cars like you said.
Marcus Anghel
