Author Topic: 1967 Shelby Hood hinges and alignment. Techniques.  (Read 1861 times)
1967 eight barrel
  • Guest
« on: March 06, 2016, 04:16:51 AM »
Does anyone have simplified instructions for initial set up of the hood hinges and alignment procedures for the hood? The Shelby factor shouldn't make a difference, however I know how the hinges are set up will determine if the hood sits up above the cowl, which seems to be very common.
Anyway, if there is a Youtube video, or you've mastered the hood alignment help would be appreciated.
Segment two. Being this is a replacement hood, there are no holes for the hood pins. I noted from the OE remnants that the holes were much larger than the pins. Could someone give me a measurement off their original hood?
        Keith
1967 eight barrel
  • Guest
Re: 1967 Shelby Hood hinges and alignment. Techniques.
« Reply #1 on: March 12, 2016, 08:41:08 AM »
I guess no one here has ever installed and aligned a hood and hood hinges, so here is a link that sheds some light on the subject matter.
http://falconccwa.stormloader.com/bonhint.htm
Offline preaction
« Reply #2 on: March 12, 2016, 11:35:18 AM »
Keith, Im in the process of doing this also and have had the same issues as this guy listed, his info is very good thanks.
1967 eight barrel
  • Guest
« Reply #3 on: March 13, 2016, 11:10:32 AM »
The painter made a mistake on my hood and took it off before the vehicle came home. He didn't mark anything, so I am essentially starting over. He also aligned it without the springs on the hinges. Makes sense to get it all aligned before the engine goes back in. I won't have to fight the booster or anything in the process.
        -Keith
