Author Topic: Correct radiator cap for Oct64 SJ  (Read 1418 times)
Offline DKutz
« on: March 06, 2016, 02:11:32 AM »
Looking to replace my incorrect cap with a correct radiator cap.  NPD has four different versions for a 65.  Zinc, chrome, something else and a high pressure cap.  Which one is correct for an Oct 64 SJ A code?
Re: Correct radiator cap for Oct64 SJ
« Reply #1 on: March 06, 2016, 02:16:42 AM »
SMCO zinc plated would be most typical for your application.
Offline 66RavenGTCoupeAgain
« Reply #2 on: August 30, 2018, 06:49:28 PM »
Hi Guys,
I have a 65 Vert same plant same month. Just wondering if this Motorcraft cap is a service replacement or a factory installed unit or was it just an aftermarket item?
Thanks in advance
Dan
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
« Reply #3 on: August 30, 2018, 07:16:15 PM »
Service replacement since the Motorcraft line replaced Autolite in the 1971-72 timeframe if I recall correctly
« Reply #4 on: August 30, 2018, 09:01:09 PM »
+1 - service replacement
« Reply #5 on: August 30, 2018, 09:11:00 PM »
Thanks Guys.
Would it be of any use as a concours part for anyone? If so what models?
« Reply #6 on: September 01, 2018, 01:20:40 PM »
Thanks Guys.
It is only good as a emergency spare relative to a 60's Mustang. That is still good to have for that reason.
Offline RAH2 1964.5
« Reply #7 on: September 01, 2018, 06:38:14 PM »
This is the radiator cap I purchased for my May 8, 1964, Dearborn, 260v convertible. Is it correct?
Thanks Roger
05/08/64, Dearborn, Convert., DSO Phil.
Raven, Stand. Int., White with Black Trim
AT, 260v, PS, Console
2003 Cobra Convert., Torch Red, 10th Anniv., Stock
2006 GT Coupe, Redfire, Factory Stripes, Stock (Shaker Intake)
« Reply #8 on: September 02, 2018, 12:00:25 PM »
Yes
Offline RAH2 1964.5
« Reply #9 on: September 02, 2018, 12:16:48 PM »
Thanks Roger
