Author Topic: Original Seat Belts + Retractors 1967 Deluxe  (Read 5435 times)
Offline Ralf
« on: March 05, 2016, 10:59:06 AM »
Hi,
Would it be possible that smb could post some detailed pictures of original Seat Belts + Retractors 1967 Deluxe?
Need to see especially the zinc plates incl. screw (fixation floor body) and buckles.
Thx
Ralf
Re: Original Seat Belts + Retractors 1967 Deluxe
« Reply #1 on: March 05, 2016, 10:43:01 PM »
A investment in a set assembly manuals would pay for them selves in answering many of your questions.
1967 eight barrel
  • Guest
« Reply #2 on: March 06, 2016, 12:50:30 AM »
Ralf,
I'll scan pictures from the assembly manual for you. My  Shelby's belts are still out, if you need a picture of something in particular. Some don't realize you're in Germany and what it cost to buy, ship and pay for the VAT. Let me know what you need, I'll square you away.
        -Keith
« Last Edit: March 06, 2016, 02:34:22 AM by 1967 eight barrel »
Offline Ralf
« Reply #3 on: March 06, 2016, 02:47:28 AM »
Thx Keith.
In general, does the manuals have coloured pictures? That would be great. 8) Because I'm looking especially for the colour of the materials. ;)
May be I did not not clearly express this in my first post.
One of the reasons, I gonna do new zinc coating on the (floor) metal plates. Question to me....yellow or silver zinc plating.
Ralf
« Last Edit: March 06, 2016, 04:36:36 AM by Ralf »
1967 eight barrel
  • Guest
« Reply #4 on: March 06, 2016, 04:22:19 AM »
Ralf, With the exception of the thick washers that goes on the carpet side of the seatbelt bolts and in your case, the rubber washers, it was all gold zinc. If you have original shoulder harness option, that changes things as well a little bit. The assembly manual are line drawings. It gives fastener numbers and the order of the parts for assembly. The bolt part numbers are coded that identify what finish a particular fastener used.
As for colors, there's not that many, so it should be pretty easy to figure out.
Offline Ralf
« Reply #5 on: March 06, 2016, 04:34:04 AM »
Thx for clarification. I do have a Convertible ;-)
« Reply #6 on: March 06, 2016, 03:51:44 PM »
+1 . They include finishes for the fasteners .
Offline Paperback Writer
« Reply #7 on: March 06, 2016, 09:42:49 PM »
FYI - Because of the inner rocker panels that were used on the '67 Convertibles, the factory seatbelt retractors cannot be installed...
« Last Edit: March 06, 2016, 10:36:45 PM by Paperback Writer »
1967 390 GTA Convertible
7R03S110###
« Reply #8 on: March 06, 2016, 10:21:21 PM »
FYI - Because of the inner rocker panels that were used on the '67 Converibles, the factory seatbelt retractors cannot be installed...
+1
Guess that should have been one of our first questions - to confirm that the poster was askign about the car in his signature
Offline Ralf
« Reply #9 on: March 07, 2016, 02:46:41 AM »
I do have a 67 Convertible, built as shown in my signature.
Seat belts LH/RH are currently w/o retractor. However, I could buy some "factory" FOMOCO seat belts which do have rectrators to exchange my current ones.
Thats the reason for my question as well. Does this car had factory seat belt retractors (rollup) driver/passenger? If not, would it make "sense" to build them in?
Thx.
Ralf
Offline 196667Bob
« Reply #10 on: March 07, 2016, 03:34:00 AM »
Ralf : As noted by Paperback Writer, "Because of the inner rocker panels that were used on the '67 Convertibles, the factory seatbelt retractors cannot be installed...".  IMO, you'd have to do considerable modification in order to safely use the Factory retractors that were available for the other Models.
Attached is a picture of what I'm using on my Convertible; original Ford accessory, and correct for '67.
Bob
MCA 04909
Offline Ralf
« Reply #11 on: March 07, 2016, 04:09:16 AM »
Means, I can not use these (unless a modification....which ?.... needs to be done):
My car came with deluxe interior factory (interior decor group). Nevertheless, Marti does not mention "Deluxe Seat Belts".
Ralf
« Last Edit: March 07, 2016, 07:28:56 AM by Ralf »
« Reply #12 on: March 07, 2016, 11:25:08 AM »
Thx.
Ralf
As others have said the convertibles did not come with retractors. You don't want retractors on a convertible unless they are the small optional assesory type for reasons already mentioned . NPD has a spot on repro of those in their catalog. Keep or restore the ones you have.
Offline Ralf
« Reply #13 on: March 07, 2016, 11:29:03 AM »
The main purpose to me....better and easier handling of the belt with retractor.
Ralf
Offline 196667Bob
« Reply #14 on: March 07, 2016, 12:04:09 PM »
Ralf : Just to make it clear, the Retractors you pictured were "Standard" on all Models except Convertibles. The Deluxe Seat Belt Option included "Push Button Seat Belt Buckle Release" (as opposed to "fingertip" release, and the Seat Belt Warning Light. Retractors were not part of the Deluxe Seat Belt Option.
In the 1960-68 MPC, under "Front Seat Belt Assembly", for 1967 Mustang Convertibles, it specifically states (for both Standard and Deluxe Seat Belts), "Without Retractor". In addition, at the bottom of the listing it notes "For Retractors, See Accessory Section, Group 611A06", which shows the "Accessory Retractors I previously pictured.
To use the ones that were Standard for Coupes and Fastbacks would not only require major modification to the Rocker Panel, but could be an issue for your safety.
Unfortunately, those of us with Convertibles will have to settle for the "Accessory Roll-Ups".
Bob
MCA 04909
