Author Topic: Air Conditioning Compressor Tag  (Read 1306 times)
Offline momsmustang
« on: March 03, 2016, 10:20:31 AM »
I am working on a 1966 mustang 289 V8. Need to put the aluminum 5 sided tag on the compressor. I believe this mounts under the bolt that holds the brace going to the intake manifold. Is that correct? Also does it go above or below the brace. Thanks.
Offline lancelot66
Re: Air Conditioning Compressor Tag
« Reply #1 on: March 03, 2016, 01:36:48 PM »
Reference page 2 in another thread from a short time ago:
http://www.concoursmustang.com/forum/index.php?PHPSESSID=nj5ofilp8cjl21q2c98k9jen26&topic=12176.15
Jeff has posted pictures of what you're wondering about. Illustrates it perfectly. Tag on top of the compressor, brush wire clip next, then the brace. Clocking of the tag (as you're looking at it from the front of your car) has tended to vary, from what I've seen. I have ours clocked with the bottom of the tag at the 3 o'clock position, so you can read it from the drivers side of the car. Just my choice here...
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
Offline momsmustang
« Reply #2 on: March 03, 2016, 05:57:35 PM »
Thank You. Just what I needed.
Offline trucktricksdon
    • Direction Auto & Truck Accessories
« Reply #3 on: March 04, 2016, 04:01:22 PM »
Is the mounting of the compressor tag the same as pictured above on an 11/64 San Jose coupe A code? If so, I may need to change mine...
« Reply #4 on: March 04, 2016, 06:13:25 PM »
Response #23 shows a 65 San Jose car from Feb 65. Closest picture/car I have to your car's time period
« Reply #5 on: March 08, 2016, 05:57:01 PM »
Thanks Jeff.
