Author Topic: Sept 64 built SJ Carpet Screws  (Read 2541 times)
Offline 66RavenGTCoupe
« on: March 01, 2016, 05:09:55 PM »
Hi Guys,
So I have these two carpet screws on the rear of the p/s seat pan but not on the d/s. Should they be there and are there any others as I have one on each door pillar too?
Dan.
« Last Edit: March 02, 2016, 12:30:42 AM by 66RavenGTCoupe »
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: Carpet screws
« Reply #1 on: March 01, 2016, 08:34:26 PM »
I've not seen that on a 66 NJ car so I would suspect it was a fix for a poor fitting carpet on the line. That would explain why it was only needed on one side
Just a guess but expect that the other NJ owners will be adding their observations
« Last Edit: March 01, 2016, 08:39:49 PM by J_Speegle »
Offline mjd 65
Re: Carpet screws
« Reply #2 on: March 01, 2016, 11:45:10 PM »
I don't have any information for 66s, but there are no screws or evidence of screws in the carpet on my late 65 Metuchen coupe.
Mel
Offline outlawincorporated
  • Kangaroo Herder
Re: Carpet screws
« Reply #3 on: March 01, 2016, 11:46:14 PM »
don't believe it is his 66 NJ car Jeff, more like a 65 SJ example.
always helps to include vital information when doing a post so we don't get caught up in mis-information
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Re: Carpet screws
« Reply #4 on: March 01, 2016, 11:48:09 PM »
Yes have no idea given how it was presented.
Double - "haven't seen that" if its a 66 San Jose example. :)
« Last Edit: March 02, 2016, 12:36:49 AM by J_Speegle »
Offline mjd 65
Re: Carpet screws
« Reply #5 on: March 01, 2016, 11:57:42 PM »
The Osborn 65 Assembly Manual does show four screws in the carpet on non console models, but in a different location.
Mel
Re: Carpet screws
« Reply #6 on: March 02, 2016, 12:09:58 AM »
Not sure if he was asking about a 65 or 66  but yes they actually did that on the line
Different side of the seat pans, different screws and different part of the pan.
66 Example - screw is located in the lower right corner of the picture below
From this tread ;)
http://www.concoursmustang.com/forum/index.php?topic=5371.msg30157#msg30157
Re: Carpet screws
« Reply #7 on: March 02, 2016, 12:14:02 AM »
And a different type head, round washer, as opposed to a flat head. A flat head does not have very good carpet retention properties.
Re: Sept 64 built SJ Carpet Screws
« Reply #8 on: March 02, 2016, 12:32:36 AM »
Sorry guys,
Did this in a rush before work this morning. I've altered the title to reflect the car.
Thanks for the help so far.
Has anyone ever seen them on the pillars near where the seatbelt bolts are?
Dan.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline DKutz
« Reply #9 on: March 02, 2016, 01:09:04 AM »
My October 64 sj car had screws on one side not the other...
« Reply #10 on: March 02, 2016, 02:03:24 AM »
Front edge of the seat pan/seat installed from above? Or vertical on the back side of the pan/riser
Have seen some cars where the worker ran out of time or missed leaving no hole in the floor metal but IMHO not that common.
Offline DKutz
« Reply #11 on: March 02, 2016, 03:41:06 PM »
installed from above on one side only...
