Author Topic: Repro 65/66 Rear Spring Lower Small Leaf ?  (Read 1256 times)
Offline flyingfred
« on: February 25, 2016, 01:26:09 AM »
I inspected a car the other day that had such a crisp number stamping on the small spring leaf that I am really believing it to be a repro. Has anyone else heard of this? I have seen a lot of stampings and they are not usually that easy to read but this one appeared to be freshly stamped as the indentations were still shiny.
-Fred-
« Last Edit: February 25, 2016, 04:25:33 AM by flyingfred »
Re: Repro 65/66 Rear Spring Lower Small Leaf ?
« Reply #1 on: February 25, 2016, 05:12:57 PM »
Did you get a picture?
I often run across service replacements that are neatly "stamped" into a short leaf that is not shaped like originals. Numbers often suggest that they were made in the mid to late 80's
Not sure if that is what your seeing
« Last Edit: February 26, 2016, 01:54:57 AM by J_Speegle »
Offline flyingfred
« Reply #2 on: February 25, 2016, 09:58:45 PM »
Thank you for your response, Jeff.
I did not take a picture but I did write down all of the stampings:
C4ZA 5556 S
296E4
The S was much more heavily stamped and not straight into the metal like the rest of the stamps. It was as if the "S" stamp was leaning to the right hand side when struck. Both springs were identical.
-Fred-
« Reply #3 on: February 26, 2016, 01:58:46 AM »
Hmm haven't seen a "-S" that was slanted
the "296E4: suggest that they were stamped Oct 23rd 1964
Offline flyingfred
« Reply #4 on: February 26, 2016, 02:15:53 AM »
Thank you for your observations, Jeff. I had not seen this anomaly before either and both sides were identical.
-Fred-
