Author Topic: Differential markings - 65 SJ FB  (Read 6049 times)
Offline JeffD
Re: Differential markings - 65 SJ FB
« Reply #15 on: March 21, 2016, 11:37:40 AM »
try a thin putty knife to break the seal. that worked for me
Jeff Deaton
64 1/2 D-Code - in progress way too long....
Body   65A   Color M   Interior 56
Date 15G   DSO 24   Axle 1   Trans 6
« Reply #16 on: March 21, 2016, 01:57:37 PM »
Any suggestions on how to remove the pumpkin from the housing?  All the nuts are off and it is not budging.  There was a lot of some kind of sealer around the edge between both surfaces and noticed they had forgotten to put the copper washers (and axle tag) back when they re-assembled it.  There isn't much to pry on to pull it apart...
Ummm...don't forget to first remove both rear axles.  The pumpkin won't come out with the axles installed.   :P
Offline ChrisV289
« Reply #17 on: March 21, 2016, 03:29:35 PM »
Those have been out for a couple of weeks now  ;)  While on the subject, what color is everyone using for the red oxide?  It appears to be more orange red than a deep red per the pic with the bottom of the pumpkin with the 8 marking...
2009 V6 Mustang Coupe
« Reply #18 on: March 21, 2016, 07:01:50 PM »
Been using the PPG epoxy primer (red oxide color) straight out of the can. Guess a little tinting would be good if your going after the more orange - if that is not a result of the flash and the true color
Offline ChrisV289
« Reply #19 on: March 22, 2016, 12:58:00 PM »
The shade is definitely different from what is underneath the car if that helps (under engine bay since back half is slop gray/black since Oct 64 car)...I can take pic without the flash on but those were taken with an IPhone.
Offline ChrisV289
« Reply #20 on: March 24, 2016, 01:24:09 AM »
Took a couple of pics without the flash on...
« Reply #21 on: March 24, 2016, 04:31:34 PM »
Thanks - would try and match the color you see inside the housing (back side of the carrier)where it was protected from elements, cleaners .......
Offline ChrisV289
« Reply #22 on: April 17, 2016, 11:14:16 PM »
Does this look about right? Doesn't seem as red as others I've seen. The paint can is on the left
« Reply #23 on: April 17, 2016, 11:21:20 PM »
Doesn't look as red,deep or "rich" as originals. Always found that if you look at the inside (since they were painted before machining as a unit) that is where some of the best color examples are
Offline ChrisV289
« Reply #24 on: April 18, 2016, 12:27:42 AM »
I used the PPG red oxide paint as suggested...Maybe need a different brand...
« Reply #25 on: April 18, 2016, 12:51:07 AM »
Believe I suggested the PPG epoxy red oxide like originally used. Not a rattle can. Didn't know that they offered a gloss red oxide in a spray can
Offline ChrisV289
« Reply #26 on: April 25, 2016, 08:19:57 PM »
Little progress this weekend. Still have to reproduce markings but now need to get it together sooner than later
« Reply #27 on: April 25, 2016, 08:21:53 PM »
looking good but i have a suggestion.....get rid of that excess sealer.
Offline ChrisV289
« Reply #28 on: April 25, 2016, 09:09:15 PM »
I am. Waiting for it to dry some before taking a razor blade to it and then taking a fine brush with some black paint to hide the gasket and what ever sealer I couldn't get
Offline ChrisV289
« Reply #29 on: May 21, 2016, 09:32:29 PM »
Last week before going back in the car. Tried to match the handwriting but not perfect.
