Author Topic: 69 vs 70 doors  (Read 2427 times)
Offline JohnRB
  • 0F03R120303
69 vs 70 doors
« on: February 21, 2016, 02:21:57 PM »
Anyone have a side by side pic with the differences between the 69 and 70 door inner structure?
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
Re: 69 vs 70 doors
« Reply #1 on: February 25, 2016, 03:40:27 AM »
The 70's don't have door tag holes and at the bottom corners they made a change for the Mach trim.  Notice in the picture of one corner I repaired a rust issue the other day, on a 70 door, they made a bend in the inner structure for a hole for the stud to come thru.  Front and rear.
MCA#31064
Re: 69 vs 70 doors
« Reply #2 on: February 25, 2016, 01:27:37 PM »
Not clear on what ' door inner structure ' means ?  This picture is of a 69 door without the 70 stud provision Armond pictured.  Something specific you are looking for ? Brian
« Last Edit: February 25, 2016, 01:29:45 PM by Brian Conway »
Offline JohnRB
  • 0F03R120303
Re: 69 vs 70 doors
« Reply #3 on: February 25, 2016, 05:22:51 PM »
Just found out the same thing after looking at several 69/70 Mustangs.
Thanks for confirming it.
Re: 69 vs 70 doors
« Reply #4 on: March 23, 2020, 07:24:17 PM »
Another picture showing the difference.
The most visible difference between 69 and 70 doors is the inner shell/panel in the lower corner where, during 70 production, they reshaped this area to provide a more solid attachment point for the exterior Mach I trim.
A picture to illustrate. In the 70 example you can see that there is a section of that inner shell that had to be reshaped and for Mach I's a hole drilled. Hope this helps others in their understanding of these differences
Offline Vcode
Re: 69 vs 70 doors
« Reply #5 on: March 23, 2020, 09:15:44 PM »
