Author Topic: Slop? Overspray? Something else? July 64 Dearborn  (Read 3848 times)
Re: Slop? Overspray? Something else?
« Reply #15 on: February 21, 2016, 08:31:54 PM »
Depending on plant and time period examples have been found like the example posted. Especially noticeable on cars with high contrasting colors such as exterior white.
On a restoration you should still be able to see that the outer edge is direct application and the majority of the inner area is a heavy misting. As mentioned the white really makes it stand out. In comparison a Poppy Red exterior over a red oxide floor makes the over spray (if applied this heavy) almost disappear
Offline jtfx6552
« Reply #16 on: February 23, 2016, 11:38:26 PM »
as i mentioned earlier - i had no red oxide originally visible underneath. i also, through sanding, have not seen any under the layers of history.
was your car having that much body overspray? it looks like it goes about everywhere
There was a lot! I think the old time guns really let the overspray fly.
« Reply #17 on: February 24, 2016, 04:53:11 PM »
+1  More difficult to do with these new guns
