Author Topic: Firewall holes on 1969 Mach1  (Read 11182 times)
Offline Aussiemach
  • Silver Level Subscriber
« on: June 05, 2010, 09:49:17 AM »
I need to check which holes are correct and which need to be filled in. Along with the Mach1 details below it has factory power steering, standard heating and drum brakes, but I'm changing to factory air conditioning and power brakes (comfort and safety).
I have filed the hole so the power brake master cylinder fits.
Are all of the holes numbered 24 used with factory air?
Also is number 16 used for the blower motor wire with factory air?
Here is my list;
1 Engine Earth
2 Sealing Grommet
3 Throttle Cable
4 Wiring Loom
5 Brake Line Holding Clips
6 Peg for Shifter Wire Harness Clip
7 Peg for ? Clip
8 Heater Hoses
9 Punched holes not meant to be there ??
10 Hole for After market A/C Hoses
11 plastic wiring loom retainer
12 windscreen wiper motor earth
13 wiring loom earth
14 grommet/loom wiper motor
15 point to clip plastic strap onto
16 grommet heater motor wire
17 wiper motor mount
18 brake master cylinder and pedal support
19 park brake cable
20 steering column
21 ?
22 ?
23 ?
24 heater box
25 ?
26 ?
thanks for any help, Andrew
« Last Edit: January 18, 2024, 07:43:52 AM by Aussiemach »
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
Offline jmlay
Re: Firewall holes on 1969 Mach1
« Reply #1 on: June 06, 2010, 07:42:04 PM »
Great post! I have intended to ask the same questions for my SJ 69 Mach1 but, never got around to it.
Here are a couple of corrections, the Parking Brake cable enters thru the frame rail, TQ box & then thru the floor-pan. Someone will correct me if I have missed any.:
7 - Peg for plastic strap to hold brake line (under #5 there is another stud for a like strap to hold the wires to the hood scoop turn signals if equipped)
10 - Clutch Rod
19 - Speedo cable
21 - Trans Cross-member
22 - (Not sure what this is but I have several pictures with 2 items extending from it)
23 - Wire feed (neutral safety switch, Oil sender, Wiper motor)
25 & 26 - Accelerator pedal screws
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Offline Aussiemach
« Reply #2 on: June 07, 2010, 10:20:06 AM »
Thanks Mike that's narrowed it down a bit, it's been a long time since I pulled everything apart!
10 - Clutch Rod, should this hole be blanked off for FMX trans? if so does anyone have a photo?
Offline jmlay
« Reply #3 on: June 11, 2010, 06:12:38 PM »
My c6 equipped SJ Mach1 does not have a hole here.
Mike
San Jose
Released: 1/8/1969
Offline Sluggo
  • Dark Overlord
« Reply #4 on: June 12, 2010, 12:48:45 PM »
Here is a 69 San Jose factory air car.
You'll notice a large hole under the pinchweld which I have plugged because I'm mounting a brace there.
This hole is where the vacuum hoses come out for the ac controls.
There are also two plates that cover the heater and ac hose area.
MCA 55330 | 69 Mach1 | 427 Stroker | 29 Model A Murray Town Car | 4 Banger
Offline Sluggo
  • Dark Overlord
« Reply #5 on: June 12, 2010, 12:58:14 PM »
10 - Clutch Rod
19 - Speedo cable
22 is a rubber locator of some sort. Maybe to center and hold the firewall insulation in place. I'll try to get under the dash and find out what it is.
13 is ground for hood scoop mounted turn signal harness.
10 is not the clutch rod.
« Last Edit: June 12, 2010, 01:03:41 PM by Sluggo »
Offline Aussiemach
« Reply #6 on: July 15, 2010, 11:14:07 AM »
Thanks for those replies, Number 10 will be plugged and will make provision for the heater hoses near where the a/c lines go as in Sluggo's pic
Offline DEWilson
    • Maine Mustang Back from the Dead Restoration Shop
« Reply #7 on: September 07, 2010, 02:08:37 AM »
#22 is the hole for the rubber plug pin that hold the fire wall pad in place a long with the one between the #1 and # 8 that is marked in with the #24 grouping
Offline joe747
« Reply #8 on: November 11, 2010, 10:44:35 PM »
i think that number 19 must be wrong
Offline joe747
« Reply #9 on: November 11, 2010, 10:49:05 PM »
21 is for the bolts for the tranny support
22 firewall pad plug
23 harness from dash to engine
 25 (& 5 ) gas ped screws
26 brake line clip
