Author Topic: 1967 lighting/main engine compartment harness routing.  (Read 927 times)
1967 eight barrel
  • Guest
« on: February 14, 2016, 07:20:35 PM »
I am going by memory, but is the main loom that runs from the driver's side to the right side starter solenoid routed through the core support and through the battery tray supports? I don't remember it just laying on the right frame rail.
        -Keith
Re: 1967 lighting/main engine compartment harness routing.
« Reply #1 on: February 14, 2016, 07:42:30 PM »
Yes it's typically found running above the lower battery tray support attachment points, holding it up away from the passenger side frame rail
Generically there are a couple of older threads related to the location of vacuum canisters on 67 and that routing is shown in a couple of those examples
« Last Edit: February 14, 2016, 08:57:46 PM by J_Speegle »
1967 eight barrel
  • Guest
« Reply #2 on: February 14, 2016, 08:10:27 PM »
Jeff,
Thanks. I couldn't get anything to come up in the search. I see it now, looking at the rust bucket that only has a portion of the tray left. Thanks for the assistance. It is now routed behind the tray support.
        -Keith
