Author Topic: 67 a/c condensor  (Read 1513 times)
Offline preaction
67 a/c condensor
« on: February 13, 2016, 06:08:46 PM »
Does anyone have a picture of a 67 a/c condenser for identification purposes. I have one but it seems that there are not many around.
« Last Edit: February 14, 2016, 10:27:46 PM by carlite65 »
Re: 67 a/c condersor
« Reply #1 on: February 14, 2016, 02:15:06 AM »
i have several nice used ones if you can't find any. I had a junk one that I laid on top of a later service one to compare the difference . The elbow on the bottom and the holes in the strap to name a few. I hope this helps.
Offline preaction
« Reply #2 on: February 14, 2016, 10:21:04 PM »
Bob, as I look at my condenser it seems the part with the holes looks similar  but are you seeing the ends as different ? It seems my tubes are round and yours are flat. Bob are 67 condenser's a one year part ?
« Last Edit: February 14, 2016, 10:23:19 PM by preaction »
« Reply #3 on: February 14, 2016, 10:58:46 PM »
The same condenser was used 67/68 from everything I have seen.
Online 67gta289
Re: 67 a/c condensor
« Reply #4 on: February 14, 2016, 11:25:58 PM »
I've seen the same as Bob, example from 7F01C129xxx
« Reply #5 on: February 15, 2016, 05:35:49 AM »
Clearly your example is not consistant with what is typically found on 67 Mustangs. If you look only at the metal cap alone (the one with the perforated holes) you can see in all 3 examples that Bob & John have shared, the metal cover caps over (covers) the flat, "serpentine style" tubing on the ends, (the flat tubing that runs throughout the condenser) There should be no round tubing at all used on any original condensers that I have ever seen.
My original 67 condenser matches up with the two original condensers shown (one from Bob, other from John).
Classic Auto Air sells a very similar to OE design sepentine type reproduction condenser (a bit pricey). It IS DIFFERENT too!
My thoughts are that if you intend to be as authentic as possible and somebody already mentioned they have an original one available, (in another thread recently?) it might just be worth the cost to simply pull the trigger and buy one. These original ones are not very easy to locate and quite likely, anything else reproduction will be noticed on the show field.
« Last Edit: February 15, 2016, 07:51:16 AM by 67gtasanjose »
