I'm getting parts back on my 67 Dearborn 390 after cleaning to prep for painting. There are pics and discussion about the PCV and related parts but there are a few questions I have about other areas. Does the gulp valve mounting bracket get painted blue ? Does the harmonic balancer get blue paint or installed after blue paint and does the balancer get painted black ? I'm guessing that the crab mounting pad and crab studs were masked off. IIRC the thermactor pump mounting bracket is installed before paint. Fuel pump is not installed for engine paint. I don't know if the oil filter adaptor is or is not installed for painting. Should the timing pointer and attaching screws be painted ? Water pump bypass and clamps do get painted. Does the brake booster hard line from the manifold get painted ? I realize that the manifold fitting for this does not get blue paint. I will try to post some pics of where I'm at now.
Thanks Jeff and Bob, what would be the correct finish for the gulp valve bracket ? And if the bracket is installed after engine paint then the attaching bolts for the bracket and the valve would be P&O ? Was the dip stick tube also installed before paint ?
Are there any a/c mounting brackets installed before paint ?
No those were added at the plant that year from my understanding
One more detail is the water pump hub masked or painted blue ? ....
Thanks Jeff, am I remembering correctly that no gaskets are used for the exhaust manifolds. Engine lift hooks blue ?
