Author Topic: 1967 Mustang wiper motor mounted to bracket...  (Read 1943 times)
1967 eight barrel
  • Guest
« on: February 10, 2016, 06:38:52 AM »
I was wondering if anyone had their wiper motor still mounted to the bracket and off the vehicle? I need a picture to see which way the wiper motor lever is pointing when the wipers would be in the "parked" position.
        -Keith
Re: 1967 Mustang wiper motor mounted to bracket...
« Reply #1 on: February 10, 2016, 12:32:03 PM »
Mine is back on the car but I did have this pic which might help
1967 eight barrel
  • Guest
« Reply #2 on: February 10, 2016, 09:56:30 PM »
John, that is it!  Thank you!  That is in the "at rest" position? I wanted to make sure the motor arm was clocked correctly before putting into the Shelby.
                                                         -Keith
« Reply #3 on: February 10, 2016, 10:25:57 PM »
                                                         -Keith
FYI if unsure in the least I would not install the wipers but run the motor and verify were it settles before installing . I saw what happened during a operational check in concours (typically don't check wipers but did this time ) . It was not pretty and arms scratched cowl. Also , Trico "satin"not polished arms , Trico marked satin 15" wipers holder -just in case that question is in the near future.
1967 eight barrel
  • Guest
« Reply #4 on: February 10, 2016, 10:28:14 PM »
Bob, thanks!  You would be proud. I have a pair of NOS Trico arms, which are more satin than polished like the Drake repros.
I won't be installing the arms until all the harnesses are back in, which is just the under-dash unit at this point.
Thanks again for the heads up and the prompt responses.
        -Keith
« Reply #5 on: February 10, 2016, 11:06:58 PM »
        -Keith
Speaking of under dash ,the electrical assembly manual is great to use with its underdash illustrations for layout the wiring harness etc.
« Reply #6 on: February 11, 2016, 06:39:12 AM »
Keith, yes that was at rest.
Even though I was absolutely confident of that, I did exactly what Bob said in his reply - I did a try run.  Bolted everything in place, and with a temporary setup using a power supply (a battery could be used), I ran the motor, making sure that the linkages were doing as I expected. No wipers were installed at the time, just in case.   It ran well and parked fine.
I figured once I put all of the other stuff (steering column, console, air cond) in the way, if there was a problem with the wiper system, it would be a big bummer to have to go backwards.
Actually every piece that I put back I consider what I could do to test it.
