BIG one - did you do all the sealant applications on the firewall? Assuming that you have the main wire loom installed under the dash
- Furniture pads or a bunch of cardboard to protect the shock towers from a slight tap from the engine during the process.
- Pretty sure you didn't install the shock tower supports or shocks yet
- Have all the bellhousing, flywheel and associated bolts, details and ready
- Exhaust manifolds installed? Heat shield isn't easy to install once the engine is in the car but you run a big risk if its on the engine during install. Your call
- Engine mounts installed? Long bolts and nuts detailed?
- Have a method to hold up the rear of the engine until you install the trans?
- Engine plate painted/detailed leaving the face bare around the starter location?
- Leaving the front crank pulleys off to give you more clearance with the radiator support?
- Engine at TDC and the dist out or installing the engine with it in place.
- Watch and anticipate how things will end up if your using a chain to life the engine. Once tension is applied the direction can change quickly. Have seen dist broken, valve covers dented, aluminum intakes broken .....
All I can come up with at the moment off the top of my head
