Author Topic: water pump paint  (Read 2045 times)
Offline DKutz
water pump paint
« on: January 29, 2016, 06:04:45 PM »
So water pump was painted on the engine.  Was the whole thing sprayed black with the block?  shaft and all?
Oct 7 64 SJ build
P.S. This post will be moved, I am sure of it...
Re: water pump paint
« Reply #1 on: January 29, 2016, 06:37:47 PM »
Water pump would be attached before engine paint.
Offline DKutz
« Reply #2 on: January 29, 2016, 09:24:59 PM »
I know that, is the whole thing painted black?  Including the shaft etc?
« Reply #3 on: January 29, 2016, 09:51:55 PM »
I usually tape up the shaft and end.  It can't be seen once the pulley is installed.
Offline DKutz
« Reply #4 on: January 30, 2016, 12:46:29 AM »
Told you it would be moved!
« Reply #5 on: January 30, 2016, 07:36:08 PM »
Didn't want you to be wrong.  ;)
Offline midnite cruiser
  • midnite cruiser
« Reply #6 on: August 14, 2016, 10:34:34 PM »
Triple checking water pump color on a this July 64 D code pump. When I cleaned it up, it really did not look like it had any black on it.
It is the C-5AE-8585 C
JWhite
64.5 D code convert. / C4 / AC / PS / RP
« Reply #7 on: August 14, 2016, 11:46:11 PM »
The pump, timing cover and attaching hardware (plus a lot of other items) were on the engine when it was painted. New replacement pumps were not painted. Rebuilt pumps are/were a different story. The original paint "may" not have been entirely removed.
