Author Topic: C5ZZ-18813-A antenna  (Read 3191 times)
Offline preaction
« on: January 27, 2016, 03:34:54 PM »
Is this a assembly line part or a service replacement for a 65 to 68.
Re: C5ZZ-18813-A antenna
« Reply #1 on: January 27, 2016, 04:33:46 PM »
Fourth character of the engineering number is a "Z", that spells service replacement.
Offline preaction
« Reply #2 on: January 27, 2016, 05:53:33 PM »
I seem to have come up with C5AZ-18813-J as an original is that correct ? I didn't realize this number too had the Z in the fourth place.
« Reply #3 on: January 27, 2016, 07:38:00 PM »
I don't believe it is any different than the other, except maybe the cable lead.
Going by the decipher guides,  C5= 65, A=Ford generic or full size and again Z=service replacement
« Reply #4 on: January 27, 2016, 10:08:08 PM »
67-68 are different from the 65-66 I believe
Should be a thread or two if I recall correctly
Offline 196667Bob
« Reply #5 on: January 27, 2016, 10:09:34 PM »
The C5AZ-18813-J Antennae is a rear quarter mount antennae, catalogued in 1966 as RH and LH, and sold together in two boxes. The two antennae are identical, but the instructions note that only one need be hooked up to the radio.
I've attached a few pictures, for your "Viewing" as opposed to "Listening" pleasure.
Bob
MCA 04909
« Reply #6 on: January 27, 2016, 10:13:56 PM »
you have to look at physical characteristics because two types were bagged or boxed using those numbers.That is if you want a historical correct looking  assemblyline /dealer installed version.
Offline 196667Bob
« Reply #7 on: January 27, 2016, 10:24:21 PM »
+1 on 1967-68 being different. They carried Service Part No. C7ZZ-18813-A.
Bob
MCA 04909
« Reply #8 on: January 27, 2016, 10:32:22 PM »
Bob
FYI you can find the correct looking 67/68 antenna sometimes in the C5 marked paper bags . That is why you have to give it a visual once over to confirm.
Offline 196667Bob
« Reply #9 on: January 27, 2016, 10:36:42 PM »
+1 on the visual.
Bob
MCA 04909
Offline preaction
« Reply #10 on: January 28, 2016, 04:16:55 PM »
On an original is the mast pressed on to the base so as to be able to be pulled off, being assembled as a press fit I guess you would call it. I remember other threads about this but my search came up empty. Would COAZ-18A886-B be correct for a mast only replacement ?
« Last Edit: January 28, 2016, 04:39:49 PM by preaction »
« Reply #11 on: January 28, 2016, 08:04:40 PM »
the only thing I have been successful in changing was the press fit ball.
