Author Topic: Zinc Phosphating my 79 Hood Latch  (Read 2224 times)
Offline 79mustangcobra
« on: January 27, 2016, 09:25:37 AM »
I bought this NOS hood catch. They are hard to find. As of 1-2016 there is one left out there on partsvoice.com for a 79.
In this post I showed how I used Evaporust to clean it.
http://www.concoursmustang.com/forum/index.php?topic=12773.0
I thought I was done, but I realized that it needs to be recoated.
I bought this kit from here.
http://www.palmettoenterprises.net/Palmetto_Enterprises/-Welcome-.html
I bought one pint.
You need the following items-
Stainless Steel Pot
Stainless Steel Tongs
Measuring Cup
Temperature gauge
Put water in the pot and heat up to 190 degrees.
Put your part in to clean off all of the Evaporust
Take it out after 10 minutes of cleaning.
Look it over. This thing is clean.
Wear rubber gloves and pour in two ounces of the Zinc Phisphate into the 190 degree water with the part out.
Put your part in and let it soak for 15 minutes, turning it every few minutes.  Be sure to not touch the part with bare hands after cleaning. The oil from your hands can prevent the Zinc Phosphate from sticking.
Once you are done take it out of the water, put in a box and spray it with WD-40. Dry off and repeat a couple of times.
This is what the finished part looks like with Zinc Phosphate.
« Last Edit: January 27, 2016, 09:39:36 AM by carlite65 »
1979 Mustang Cobra 5.0
2P Red and 1C Black
Stock never goes out of style
MCA #70281 -  79-93 MCA Concours Judge
Proverbs 3:5-6
Re: Zinc Phosphating my 79 Hood Latch
« Reply #1 on: January 27, 2016, 09:34:06 AM »
I do this sort of thing outside either on a small electric burner or propane burner, depending on the volume of liquid, in order to prevent fumes inside the house.
« Last Edit: January 27, 2016, 09:40:02 AM by carlite65 »
Offline markb0729
  • South Jersey
« Reply #2 on: January 27, 2016, 10:54:09 AM »
Nice job.  Thanks for sharing.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
« Reply #3 on: January 27, 2016, 12:28:08 PM »
