Author Topic: 64.5 Headliner  (Read 3346 times)
Offline CW4macret
64.5 Headliner
« on: January 25, 2016, 09:58:30 PM »
Well it is slow going but so far so good. Any tip for the sail panels?
Mac
64.5, 5F07D
66 Convertible 6T08T
71 Mach1 429CJ 1F05J
01 Coupe
05 GT
08 GT500
14 GT500
Offline CW4macret
Re: 64.5 Headliner
« Reply #1 on: January 28, 2016, 03:18:39 AM »
Ok I have top lookin like it should. Any tips on the headliner that covers the sail panel?
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
Re: 64.5 Headliner
« Reply #2 on: January 28, 2016, 12:15:25 PM »
Just remember that your wrinkles are pulled out perpendicular to the lines.  Try pulling the rear corner down and back and stick it to the rear glass opening.  Don't forget the little cardboard strips that are used to hold the bottom back corners down.
Offline CW4macret
Re: 64.5 Headliner
« Reply #3 on: February 02, 2016, 08:37:28 PM »
Did you make the strips yourself out cardboard or are they special?
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
Re: 64.5 Headliner
« Reply #4 on: February 02, 2016, 10:37:04 PM »
Usually re-use originals, but they can be made w/out too much trouble.  I would use something more stiff than cardboard.
Offline mtinkham
  • That'll be easy
Re: 64.5 Headliner
« Reply #5 on: February 03, 2016, 01:38:20 PM »
Charles, are the cardboard strips unique to 64.5?  I am working on a 67 and don't recall seeing any cardboard when I removed the head liner.  Do you have any pictures that you could share (assuming it is applicable to a 67 Metuchen coupe)?  Thanks, Mark
Re: 64.5 Headliner
« Reply #6 on: February 03, 2016, 11:02:42 PM »
No, not unique to just early cars, I believe I've seen them on all coupes up through at least 68.  At the back corners, there are turn up prongs that are bent down to hold the strip on each side.
Note: This only applies to coupes, not fastbacks.
« Last Edit: February 03, 2016, 11:09:02 PM by caspian65 »
Re: 64.5 Headliner
« Reply #7 on: February 04, 2016, 06:53:55 AM »
Good topic. My '67 headliner was replaced once back in '79 and fitment since was always a bit saggy or wrinkled meeting up to the package tray and tops of the quarter trim shortly after it was "Professionally Done". Likewise, there were none of these "something more stiff than cardboard" pieces found when I removed that old headliner.
It sounds like we Coupe owners could all use some guidance on how best to duplicate something we have no original examples available to pattern a replacement from. My memory from working in a salvage yard +30 years ago, is trying to visualize the material (heavy cardboard is close, but certainly not correct) so that I can obtain a similar product from a hardware store or the likes. I am thinking it was very similar to the cardboard backing of an original door panel, am I getting close? (not hardboard or particle board)
Offline mtinkham
  • That'll be easy
Re: 64.5 Headliner
« Reply #8 on: February 04, 2016, 01:43:53 PM »
Thanks Charles.  Is this detailed in the assembly manual?  If so, I should be able to see the detail when I get home from work.  If not, does the headliner get hooked on the prongs and then the cardboard is sandwiched between the prongs and the headliner?  A picture is worth 10,000 of my words!
Offline WT8095
  • Dave Z.
Re: 64.5 Headliner
« Reply #9 on: February 04, 2016, 01:44:06 PM »
Try searching with "panel board" or "cowlboard". Here's an example, listed as about 1/8" thick, so it might be heavier than what you're looking for:
http://www.rochfordsupply.com/shop/Automotive/Automotive_Misc/Panel_Board_-_Waterproof/index.html
Dave Z.
Re: 64.5 Headliner
« Reply #10 on: February 04, 2016, 04:04:50 PM »
Here's a pic of an original, I believe it came from a 65 or 66 coupe.
It's 7.5" long, 0.5" wide and about 0.12" thick.
Re: 64.5 Headliner
« Reply #11 on: February 04, 2016, 04:15:31 PM »
Found it in the '65 Interior assembly manual, it's in the '68 ASM too.
C4ZB-6552194 Strip - Roof headlining side retaining - rear lower- 1 required each side of body.  Strip is rolled into headliner and retained by bending tabs.
The strip is installed in the back corner, the pointed prongs are what hold the headliner between the package tray area and the rear side window.
Re: 64.5 Headliner
« Reply #12 on: February 04, 2016, 04:32:15 PM »
These comments are tremendous help. Thanks Charles.
 Now if we post a "How To..." video alongside this post, something like a "Headliners For Dummies" video, then I might actually get the gist of the way it all goes together  ;D  I've watched the WCCC video, he doesn't use the headliner retainer board there, but a lot of good pointers how to stretch things into place.
Thanks Dave, I have a local upholstery shop, it's on my drive home, he may have some of this stuff sitting around.
« Last Edit: February 04, 2016, 04:44:59 PM by 67gtasanjose »
Offline CW4macret
Re: 64.5 Headliner
« Reply #13 on: February 06, 2016, 11:27:25 PM »
You guys Rock! I might actually be able to do this.  Thanks
Mac
64.5, 5F07D
01 Coupe
05 GT
08 GT500
14 GT500
