Author Topic: Valve Cover Gasket 289 2V  (Read 2365 times)
Offline Twilight65
  • Gold Level Subscriber
« on: June 01, 2010, 09:22:46 PM »
In the concours driven class for 65-66. Does it matter which material the valve cover gasket is made from?
Cork or black rubber?
Dave
« Last Edit: June 01, 2010, 10:01:03 PM by Twilight65 »
Re: Valve Cover Gasket 289 2V
« Reply #1 on: June 01, 2010, 09:24:26 PM »
which year specifically? they are painted different.
Offline Twilight65
« Reply #2 on: June 01, 2010, 09:28:51 PM »
July 65 with gold valve covers.
Dave
« Last Edit: June 01, 2010, 10:01:27 PM by Twilight65 »
« Reply #3 on: June 01, 2010, 11:53:43 PM »
The 65-66 (and later) valve cover gasket material was a rubberized cork, medium to dark in appearance.  You'll get a point deduction for plain black rubber gaskets.
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #4 on: June 02, 2010, 08:42:21 AM »
Not to hijack the thread, but in 66 the gasket got painted, right?  So color is a mute point on mine, right?
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #5 on: June 02, 2010, 10:09:07 AM »
Yes, that is correct.  The tabs need to be the correct shape though and in all the retaining slots.
Offline macdude67
« Reply #6 on: June 10, 2010, 08:28:23 PM »
ok on a mid 66 c code. are the valve covers painted on the motor when its assembled as to also have paint on the vc gasket? keeping this in mind then would the vc bolts also be painted?
