Author Topic: 67 390 distributor primary wire  (Read 1394 times)
Offline preaction
« on: January 18, 2016, 07:59:10 PM »
Is this wire reproduced, IIRC Bob Gains says it should have a ring connector at the coil end.
Re: 67 390 distributor primary wire
« Reply #1 on: January 18, 2016, 10:05:24 PM »
For a S code?
What dist are you using?
So far I'm seeing and recall the 90 degree for that application with the typical BB white boot.
Let me know and I'll dig further
« Reply #2 on: January 18, 2016, 11:23:39 PM »
That wire is reproduced and is available at Mansfield and I think NPD. It is a ring connector on the 67 BB and SB duel point centrifugal advance for sure. Not so sure on 67 Vacuum advance.
Offline preaction
« Reply #3 on: January 19, 2016, 11:44:51 AM »
The distributor is C7OF-F, for a 390 GT. There is no listing for a 390 at NPD.http://mansfieldmustang.com/06-68.jpg   Mansfield does carry this for 67-70 390GT and 428 CJ.
« Last Edit: January 19, 2016, 11:55:11 AM by preaction »
Offline 196667Bob
« Reply #4 on: January 19, 2016, 01:29:35 PM »
Bob : To answer your question on the SB with vacuum advance, no, they do not use the ring connector to the coil, but the push on 90 degree connector (see my Post of December 21 under "Parts" for documentation).
Bob
MCA 04909
« Reply #5 on: January 19, 2016, 02:34:26 PM »
The distributor is C7OF-F, for a 390 GT. ........
Offline preaction
« Reply #6 on: January 19, 2016, 02:52:36 PM »
Thanks Jeff.
