Author Topic: 69 390 fan, fan clutch, radiator  (Read 4010 times)
Offline Rusty
Re: 69 390 fan, fan clutch, radiator
« Reply #15 on: January 16, 2016, 03:56:08 AM »
Think a L2 radiator would not be correct for your time period. Of course you'll be checking for the date on the radiator to compare it to your 11/1/68 car build date as you likely will for the fan also ;)
You're right.....I hadn't thought about that yet. I have seen an L1 with an Oct 68 date code but so far that's the only one I've found. Haven't seen any L2's but I'd have to think they would be beyond my build date. Thanks for the heads up.
Rusty Maddox
1969 Mach 1, 390
Actual Build Date:  11/1/68
Assembly Plant:  Metuchen, NJ
VIN:  9T02S129xxx
 63C    T5     3A     05L      24       6       5
Body  Color  Trim  Date   D.S.O.  Axle  Trans.
