Author Topic: Rally Pac Identification  (Read 1210 times)
Offline Oz390
« on: January 01, 2016, 09:28:55 PM »
Have a RP I picked up a while ago. Unsure if it is original or not. I think it is, but could use some confirmation, as I' am more familiar with 68s.
Pic below. It has a C4 FoMoCo tag on the clock harness, good sign. The tach has ink stamp from Faria Corp, New London, CT, which I think is correct as the supplier of tachs (or one of them) to Ford.
The housing is cast, except for the fascia between the instruments, plastic.
The wires are, typically, cut. Does anyone have a photo of a OEM showing what should be there?
And there is a tiny red wire wrapped around the clock housing, and not connected to anything.  I am unsure if this is original, or some attempt at a ? ? ? by a PO.
Any info appreciated, and Happy New Year to all...
8R03S : 76A I 2A 15M 72 5 U
Re: Rally Pac Identification
« Reply #1 on: January 01, 2016, 10:48:22 PM »
I was asking the same sorts of questions about this 65 model.  Brian
http://www.concoursmustang.com/forum/index.php?topic=11807.msg71393#msg71393
Offline Oz390
« Reply #2 on: January 02, 2016, 02:45:30 AM »
Thanks, the post notes a silver face on the gauges, mine are black.. Mine says "MUSTANG over the tach, not FORD
As Faria stamped it seems legit, assuming 66 was black w/MUSTANG and 65 the chrome W/FORD...
Thanks for the info.
