Author Topic: brake/clutch assembly drums to disc change !?!  (Read 851 times)
Offline mhubert89
« on: December 31, 2015, 11:06:03 AM »
hi,
i have drum brake in front for now, i want to put somes disc brake. what i need to change in my brake/clutch assembly. what are the difference ?
thanks
Mustang Fastback 1968
289, 4 speed
Re: brake/clutch assembly drums to disc change !?!
« Reply #1 on: December 31, 2015, 12:21:35 PM »
You need a disc brake pedal which is longer than the drum version. OEM manual transmission ones are hard to find, an automatic pedal can be modified. You already have a template of the metal portion for the rubber pad.
The drum brake pedal assembly hanger can be modified for use with vacuum boosters. You will need to remove 3 of the nutserts where it mounts to the firewall.
Scott Drake offers a reproduction manual transmission disc brake pedal, that will work, but it is a copy of the 1969 pedal. It will not have the pedal return tab.
Offline mhubert89
« Reply #2 on: December 31, 2015, 01:44:15 PM »
thanks for all the info, so only things i need to change its the brake pedal ?
289, 4 speed
« Reply #3 on: December 31, 2015, 03:55:48 PM »
Yes, clutch pedal is the same.
